06-09-2010, 12:21 PM   #1
K100D Super broken -- AF motor won't engage lens
So I used my trusty K100D Super in some pretty rough conditions this past weekend and now it won't work right!
When mounting any AF lens and trying to focus, the AF motor whirrs and spins but the screw won't engage the lens, so the lens doesn't focus at all. The screw drive pin is still visible on the mount but it might be that it's been pushed in a little, it's hard to tell.
Has anyone experienced anything similar? Is there anything I can try before turning it in for repair?
06-09-2010, 12:31 PM - 1 Like   #2
Can you check if the screw protrudes slightly from the mount on the camera? It should be about 1mm past the edge, and move all the way in when the lens release button is pressed.
The only possible cause I can think of is that the above button might be jammed, and that's assuming that the lens is not broken and also properly mounted.
06-09-2010, 12:35 PM   #3
Okay, the screw protrudes about 0.3 mm above the mount. When I press lens release, it does go in all the way, but it doesn't come out all the way. I just compared to what it looks like on my MZ-6, and the screw definitely doesn't go out as far as it should -- so the mechanism isn't broken, but somehow it's been pushed in. Can I carefully unscrew the mount to see what's up, or will a million small parts go flying in every direction if I do?
(The lens is fine, I've tried it with a couple of different lenses.)
06-09-2010, 06:01 PM - 1 Like   #4
GerryL's Avatar
Try engaging and disengaging the manual switch first for the AF-MF.
It might be just that the switch isn't fully engaged.
Try it a couple of times before you try to dismantle anything.
For all you know it might un-jam it.
Good luck!
06-09-2010, 06:29 PM - 1 Like   #5
QuoteOriginally posted by Erik Quote
You can do whatever you like, it's your camera (but of course you knew that already).. Before tearing into it though, have you exercised the AF/MF lever to make sure it's doing It's job?
06-11-2010, 05:07 AM   #6
You guys were right, and I feel VERY silly: the AF/MF lever had stuck in the middle. I can't believe I didn't think to try that myself. Oh well, camera's fine! Thanks again!
af, camera, dslr, focus, k100d, lens, motor, photography, screw
AF-button: Does it engage the SR in K20D/K-7. pcarfan Pentax DSLR Discussion 5 05-26-2009 10:35 PM
Best Pentax lens from a K100D Super? weirdnjfan1 Pentax DSLR Discussion 8 04-14-2008 12:30 AM
Getting K100D super, which lens hungup Pentax SLR Lens Discussion 2 11-28-2007 10:17 AM
All times are GMT -7. The time now is 04:11 AM. | See also: NikonForums.com, part of our network of photo forums!
