06-11-2010, 03:06 PM   #16
levelred's Avatar
QuoteOriginally posted by amoringello Quote
The plain fact of the matter is that Pentax cripples their equipment and some people are looking for a way to make this work -- without switching to other brands of equipment that do not coddle and babysit their users into pure textbook approaches to photography.
agreed...
06-11-2010, 06:29 PM   #17
I've been wanting to do this a lot more lately. One of my biggest gripes with Pentax is the 1/180th sync speed. I used to fall into the "it's only 1/2 a stop, what's the big deal" camp. But now I've changed. When you're dealing with trying to control ambient light, maybe 1/2 a stop isn't a huge deal, but it might make the difference between barely holding a sky in, and not, or the difference between needing a ND filter or not to hold an f/2.8 aperture. Butthat I can live with. My real problem with it is shooting fast moving subjects in broad daylight, when you don't have enough flash power to make the flash 3-5 stops over the ambient midday sun to eliminate the motion blur caused by 1/180th. There's a a big difference in motion blur between 1/180th and 1/250th. That half a stop makes a big different with not having you mountain bikers be ghosted.
06-11-2010, 06:33 PM   #18
I've got something I want to try though, and see if I can at least sort of cheat the system. I have elinchrom BXRi studio heads, and they have a setting where you can program the slave cell to ignore whatever number of pre-flashes hat you need it to. So, all I need to do is putit on learning mode, then take a high speed sync shot, and then it will figure out that it need to ignore all but the last flash that it just saw. Then I should be able to just use my AF540 as a master to set it off. But I would still be limited by line of sight. It's worth a shot though. Even if I could just use that to sync at 1/320th with big power coming from the Strobe, it would be sweet. I'll let everyone know if/how it works.
camera, dslr, photography
Ext. Flash: Is there a way to wirelessly trigger it without firing the int. flash? dosdan Accessory and Memory Articles 3 03-19-2011 05:42 PM
Is 1/180th Max Flash X-Sync A Major Limitation? Christopher M.W.T Flashes, Lighting, and Studio 20 07-10-2010 08:15 AM
Any way to do HSS with radio trigger? Light_Horseman Pentax Camera and Field Accessories 6 01-04-2010 02:49 PM
For Sale - Sold: Metz 54 MZ-4i Digital Fully Automatic 54 GN P-TTL HSS Strobe Flash for Pentax wallyb Sold Items 4 11-12-2009 12:32 AM
HSS with a non P-TTL Flash off camera? Not Registered Flashes, Lighting, and Studio 13 12-05-2007 12:12 PM
All times are GMT -7. The time now is 12:18 AM. | See also: NikonForums.com, part of our network of photo forums!
