Originally posted by Rondec Some lenses are better than others at auto focus. To me, the DA 55-300 is my slowest auto focus lens, a lot slower even than my DA * 50-135, which is pretty slow. Not only is it slow, but it often struggles to grab focus at all and cycles back and forth. I just think it is a lens issue and not a camera issue. What I generally do is manually focus to close to where I think it should be and then let the camera tweak the fine focus from there. That seems to work better...
That's a very good point.
Some lenses are slower and seem to have more difficulties.
BUT normally not in good bright light - such as the ones described -
most of the difficulties occur in low to moderate light -
when the camera's focusing sensitivity become more of an issue -
and this is Pentax's weaker point -
however this is not normally an issue in good light -
if anything, Pentax is stronger than most of its competitors -
everything else being equal.
When a lens hunts in good light - it does mean it cannot find anything to focus on - which normally means there probably isn't anything of enough contrast to focus on - in lower light it is the same thing - but what may seem good enough contrast to our eyes, may not be so in lower light.
But focusing the lens on a distance close to the desired, and letting the camera/lens do the final fine focusing is a very good technique that mostly will mitigate any tendency to hunt.
Good post, thank you.
