Originally posted by GeneV I often go K-x with the 40 and the 21. The whole think can go in a winter coat pocket. The 70/21 is also a great combo. With a little waist pack you can add the 15.
The 21 and 70 are actually very similar in size when the hood on the 70mm is not mounted
It is true that when I go traveling with the Pentax DA limited, the 70mm doesn't get used as much as the 21 and 40. I just wish the 40mm to have better close up ability and it will take on the place of the 35mm when compactness rules in traveling. The minimum focusing distance on the 21 limited is 0.2m while the 40 limited is at 0.4m. The 40 is the limited lens that I find it surprisingly sharp even in wide open shots. And of course, it is the thinnest pancake that will make one happy while in traveling light.
I will try using a diopter on the 40/21 and report back if it serves better for close up.
[lba shameless decision]: I am sold on the 15mm limited
Thanks,
Hin
