06-20-2010, 01:18 PM   #1
K-x compatability with Takumar-a lenses
Hi.
I recently bought a K-x and i'm still having fun exploring its capabilities.
I have a question and pehaps someone can help me.
I was looking to purchase a used takumar-f 28-80 f3.5/4.5, found one on line and met with the seller and proceeded to test it on my K-x.
The K-x recognized the lens and all of the functions worked. However the problem i ran into was that at the wide end (28mm) the K-x was able to focus at all distance, but at the tele end (80mm) it would only move the lens from the closest focus of about 1 m to to about 8m. The camera could not push/pull the lens all the way to the infinity setting!
In MF mode i was able to focus all the way, and the k-x gave the correct focus confirmation at all distances.
The Takumar is quite a bit heavier then the kit lens, and also the focusing mechanism on the Takumar is quite a bit stiffer then the kit lens.
It would seem that the focusing motor on the K-x doesn't produce enough torque to drive the Takumar all the way.
Has anyone else had this problem, with other F or FA lenses?
06-20-2010, 01:33 PM   #2
Sounds like the lens itself might be broken. The Takumar-F 28-80mm is simply a cheaper version of the SMC-F 28-80mm, and thus should still maintain full auto-aperture and auto-focus functionality on the K-x.
06-20-2010, 01:52 PM   #3
The manual focusing was smooth, there was no stickiness in the movement at all. It felt much stiffer compared to the kit lens, but then again some have described the kit lens as being loose and "sloppy" when in manual mode.
06-22-2010, 05:26 PM   #4
KxBlaze's Avatar
I have never heard of any Pentax camera not being able to AF any lens unless the lens itself was at fault. Maybe one of the electronic connection pins is not functioning correctly (not stuck out all the way, not receiving enough electricity, loose connection, etc), unfortunately I would not know how to check to see if that is the problem or not.
bit, camera, dslr, focus, k-x, kit, lens, lenses, photography, takumar
Windows 7 Compatability ripple Digital Processing, Software, and Printing 5 03-03-2010 12:21 PM
For Sale - Sold: Super Macro Takumar 50mm, Super Takumar 200mm, F 35-80mm Lenses Nick Siebers Sold Items 4 02-01-2009 08:56 PM
lens compatability lorne-ranger Pentax SLR Lens Discussion 3 09-13-2008 08:03 AM
Question about backward compatability & other non-Pentax lenses bruadair Pentax SLR Lens Discussion 12 07-25-2008 11:56 AM
Lens compatability flashman77 Pentax SLR Lens Discussion 2 01-16-2008 10:54 AM
All times are GMT -7. The time now is 12:31 AM. | See also: NikonForums.com, part of our network of photo forums!
