06-20-2010, 03:54 PM   #1
jct us101's Avatar
Does the K-x have a tendency to underexpose?
I noticed this last night, during the sunset photos it worked out to my advantage, but as it got darker and darker while using AV mode I noticed that the exposures were not nearly long enough.
06-20-2010, 04:37 PM   #2
Marc Sabatella's Avatar
Shouldn't be the case in general - at least, no more so than any other ISO-compliant camera (eg, tries to make a scene a little darker than 18% on average, even if the actual scene is lighter than that). Feel free to post samples if you think your camera is doing something other than that.
06-20-2010, 06:55 PM   #3
Ecaterin's Avatar
Interesting - I've been running into the opposite issue under certain circumstances. Especially under fluorescent light I have to dial EV down so my exposure times are short enough that I don't have to worry about blown highlights when I'm processing. Either that or I aim the camera some place extra bright to meter and then snap my photo
06-20-2010, 10:22 PM   #4
With my K-x it had a tendency to overexpose. It liked -.3 EV. From what I've read, the K-7 is the opposite, liking +.3 EV.
06-21-2010, 02:12 AM   #5
KxBlaze's Avatar
QuoteOriginally posted by jct us101 Quote
I noticed that on mine too. It's second nature for me to shoot at +.3, I don't think twice about it. I shoot 95% in M mode and I always err on the + side.
06-21-2010, 07:28 AM   #6
bigdog104's Avatar
Mine seems to underexpose in very bright sunlight, I tend to shoot +1 EV. The histogram shows this as well.
06-21-2010, 08:02 AM   #7
Were you using M42 lens on it?
I believe that K-X doesn't give an accurate metering with M42 lenses.
For outdoor shots with my super-multi-coated Takumar 50mm 1.4, I have to dial in +2 EV for the correct exposure.
06-21-2010, 08:42 AM   #8
audiobomber's Avatar
I like the way my K20D exposes in Matrix mode. My K-x tends to overexpose (clips highlights).
06-21-2010, 10:34 AM   #9
QuoteOriginally posted by bigdog104 Quote
Again, this is not generally underexposure. Sounds like the camera is following the standards of exposure correctly (as they've been followed for around a century). The standards call for the camera to render scenes in "average" brightness (histogram centered half a stop or so left of center). Scenes brighter than average are *supposed* to come out looking darker than they appear in life unless you apply compensation.
06-21-2010, 11:04 AM   #10
GeneV's Avatar
QuoteOriginally posted by audiobomber Quote
I also get more overexposed shots from the K-x than other Pentax bodies. However, saying the camera overexposes may not be accurate.
Every meteriing system has its quirks, and it is up to me to learn them.
06-21-2010, 11:13 AM   #11
QuoteOriginally posted by GeneV Quote
Every metering system has its quirks, and it is up to me to learn them.
I agree with you Gene, yours is a more accurate statement.
I find it a bit frustrating that Pentax decided to push the exposure in the K-x, but it's not surprising they did, since they were criticized repeatedly in reviews for what I consider accurate exposures (i.e. protecting the highlights). I've been using CW metering with the K-x, as it seems less likely to overexpose than Matrix metering.
06-21-2010, 11:20 AM   #12
This is really what this thread is about. It's a very common complaint with new users. I think compact cameras set up an expectation that the camera will guess at what you're trying to expose, whereas with a Pentax dslr, the photographer has to make the decision.
06-21-2010, 12:19 PM   #13
bigdog104's Avatar
Not sure what a "new" user is, the K-X is my fifth SLR and second DSLR, all of them Pentax. In certain situations the camera underexposes and I compensate with EV of around +1. Again this is shown by the histogram. I am happy with the camera and don't see this as a complaint, As some folks have already said, all cameras have certain quirks and characteristics that you have to get used to.
06-21-2010, 02:23 PM   #14
GeneV's Avatar
I agree that it is a bit frustrating when you get used to a manufacturer's way of doing things, and they change it. My experience is also that the K10/20d tended to protect the highlights in a way that the K-x does not. I generally use CW for my other Pentax bodies, and perhaps I should double check that the K-x is not set for matrix.
06-21-2010, 06:54 PM   #15
There have been many threads here started by new users, where the complaint is that the K-x underexposes. When aked to show an example, they show a dark subject framed against a bright sky and/or water. It's invariably a clear case where +Ev was needed and not applied. That's what I'm talking about.
camera, dslr, photography
My ltd lens doesn't underexpose (woot) alehel Pentax SLR Lens Discussion 5 05-05-2009 12:41 PM
K20D underexpose seripusly mrechte Pentax DSLR Discussion 88 06-21-2008 06:47 PM
All times are GMT -7. The time now is 11:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
