06-21-2010, 11:01 AM   #1
K-x highlight correction
Has anyone experimented with this function? Verdict? I note that, when it is selected, the minimum available ISO setting is 400.
Thanks!
06-21-2010, 12:15 PM   #2
Ira
QuoteOriginally posted by LN108 Quote
Thanks!
Yeah, because it's assumed the highlights would get totally blown out at low ISO.
I don't use it...I read not to...but that the Shadow Correction is okay because it uses a different type of correction.
06-21-2010, 12:56 PM   #3
RonHendriks1966's Avatar
I have a K-7 an use the highlight correction very often. It's a good way to correct whitewashed spots in a frame or have them at least within control a bit more. I'm guessing the K-x works the same way. Just try it with bright lights within a average or dark frame and see how you can use it for your benefit.
06-21-2010, 01:15 PM   #4
Do these modes do more than just set EV+- adjustments? Do they add to the contrast levels, too?
06-21-2010, 08:58 PM   #5
Marc Sabatella's Avatar
They basically adjust the curves, just as you could in PP.
06-22-2010, 05:37 AM   #6
If you turn on expanded ISO, the minimum ISO drops to 200 with highlight correction on.
07-17-2010, 01:48 AM   #7
kx highlight correction
I've tried it and find that whites tend to become a bit grey and lose detail - it seems better to underexpose so that you dont wash out the highlights.
This can be assisted by using just shadow correction and keeping your exposure to the left - the shadows will lighten up a small bit and the highlights should then not be blown.
Be aware that the camera slows down the processing of the images when either the highlight or shadow corrction is on.
I have to add though that using a shadow correction function in the PP phase is a better solution for me as I get a better range of shadow correction in my software.
camera, dslr, photography
K-7 Hightlight Correction & Shadow Correction & Raw Christopher M.W.T Pentax DSLR Discussion 6 06-10-2010 03:32 PM
100 iso or Highlight Correction? jamescp Pentax DSLR Discussion 7 04-13-2010 02:50 AM
Highlight / Shaddow correction bbullins Troubleshooting and Beginner Help 9 04-01-2010 12:15 PM
Highlight and Shadow? maxmagnum Troubleshooting and Beginner Help 1 12-29-2009 07:36 PM
Highlight correction fulcrumx29 Pentax DSLR Discussion 2 08-16-2009 12:03 PM
All times are GMT -7. The time now is 12:10 PM. | See also: NikonForums.com, part of our network of photo forums!
