06-22-2010, 09:43 AM   #1
K-x debug??
Hi everybody,
sorry to bother...
OK, I found this:
https://www.pentaxforums.com/forums/787751-post364.html
but have a Q:
what is "endline character in windows" or so called CR/LF ????
thanks for help.
BR
Peter
06-22-2010, 10:26 AM   #2
Marc Sabatella's Avatar
It's what separates one line of text from another. Generlly speaking, what you get by hitting "Enter". Originally, this was often implemented as two separate characters (holdover frommanual typewriter days): a carriage return to return to the beginning of the line, and a line feed to advance the paper. If you ever used a manul typewriter, you probably had levers that could do these jobs separately as well as one lever that combined them. Not sure, but I suspect most text editors just use the single "carriage return" character (ctrl-M on most keyboards) when you hit "Enter". Very occasionally, it's necessary to still make a distinction in a computer text file between this and the line feed character (Ctrl-J). If some particular program (like the camera firmware) firmware expects Ctrl-J to end a line but your text editor uses Ctrl-M when you hit Enter, just use Ctrl-J instead of Enter.
06-22-2010, 10:50 AM   #3
axl
thanks Marc but it still doesn't work.
I create txt file named MODSET.492
write into it what it says in link above and I can press whatever (enter/ ctrl + m / ctrl + j) at the end and save it. Put it into camera, start while holding Av and nothing happnes. Camera just turns on in normal mode...
what am I doing wrong?
06-22-2010, 11:13 AM - 1 Like   #4
Have you cecked that the file is "MODSET.492" and not "MODSET.492.txt"?
(on windows known files extensions are hidden by default)
I've attached a working file, you've just to rename it.
Open a shell, go where you've saved the file then type:
Code:
ren MODSET.txt MODSET.492
File Type: txt MODSET.txt (21 Bytes, 245 views)
06-22-2010, 11:58 AM   #5
axl
QuoteOriginally posted by matam Quote
Code:
thanks a lot that did the trick!
camera, dslr, photography
Debug menu for *ist DS v2.01+ jfsavage Pentax DSLR Discussion 6 12-13-2012 01:52 PM
Anyone use K10D at debug mode? rosier19 Pentax DSLR Discussion 25 12-18-2010 07:34 PM
Debug mode on K-x. ilya80 Pentax DSLR Discussion 2 11-04-2009 05:12 AM
K10D debug, few Qs axl Photographic Technique 2 02-03-2009 08:22 AM
For those who did AF adjustment (via DEBUG) on your camera frank Pentax DSLR Discussion 16 09-21-2007 04:00 AM
All times are GMT -7. The time now is 04:47 PM. | See also: NikonForums.com, part of our network of photo forums!
