Originally posted by fergy That is exactly my point in the PM I sent Dorian, a member here who works with customer service, asking her for help. I also sent Ned an email asking (pleading) for them to make this right. I haven't heard back from either of them, but I just sent messages to them yesterday. I'm keeping my fingers crossed. I really want this camera to work. I've been using Pentax equipment since I bought my ME Super back in the late 70's, which I still have and it still works like new. Wish they made a digital back for the ME Super!
with respect to updating the firmware, the procedure on the site is pretty straightforward.
Download the file, unzip it copy the executable to the root directory of the SD card, and install it in the camera.
Press the menu button while turning on the camera and follow the prompts.
One thing caught my attention however.
You specifically mention that you had an old zoom, and it recognised the focal length of the zoom. I presume you had entered this,
Have you set the custom menu to "use aperture ring" it should be set to option 2?
If this is not set, then with a lens that does not have the aperture in the A position, the camera will do precisely....NOTHING.... when you press the button.
Also, the problem may not be the camera but the kit lens. It will behave exactly as you describe, if the pin furthest away from the lens locking pin is not making contact. You can try 2 things here, first is to clean the contacts with a non abrasive pencil eraser, the other is to apply a little torque to the lens in the mount, the lens will move a little on the locking pin and this may bring it into contact.
If there is a problem with lens contacts, you should see a flashing F--- as opposed to the aperture with the kit lens on the top LCD
