Originally posted by Lowell Goudge Check the AF selection and put it in AF-C or Manual, and see if something works differently now.
I sat there the other night and tried every combination I could come up with, including AF-C, AF-S, Manual, including all the different modes and couldn't get the camera to operate the shutter or focus. Now, I didn't try turning off the camera, changing to AF-C or AF-S or Manual, then turning the camera on in that mode specifically, but I did try everything I could imagine at the time. By the "hit and miss" method, I may have inadvertently done exactly what I just said I didn't do specifically, if you know what I mean... I also tried turning on the camera with no lens and seeing if it would activate the shutter. No luck there either.
If I go through the menus and lift the mirror for CCD cleaning, it works, and it sets the mirror back down when you turn it off, like normal. It will also do the "shake the CCD" clean function. Like I said, everything looks normal on the displays as you go through menus, change modes, hit the "F" button, it all looks like it is ready to go, but the shutter release button and the AF button do nothing, with or without a lens present.
