I guess the only solution is to test it, destroing the Pentax MV in te process.
I first will use the MV screen, if it works out well, i might try the ME Super screen. What i have heard so far, is that the screen of the ME Super is better/brighter than the screen of the MV
/update
1 MV later, have removed the screen and cut it in the right size.
Cutting the screen is much more easy as i tought, just put some sticky tape on both side of the screen, draw the cut-lines, and cut the lines on both sides of the screen with a sharp knife.
Than you can easely break the edges of the screen. Using sandpaper on a flat surface is enough to get the screen at the right size.
After removing the sticky tape, just rinze the screen with clean tap water and dry it with some kitchen paper.
The microprism and split focus of the old MV screen is much better than the focusscreen.com version. The rest of the screen is the same brightnes, but has visable patterns. Could be that this is because the MV screen isn't very good.
Maybe i will try again some day with the ME Super screen.
