06-24-2010, 06:00 PM   #1
jpzk's Avatar
K7 ... where has the metering "bar" gone in manual mode?
Hi folks,
I am not sure how this happened but now, since I started using the K7 in full manual mode, the only way I can see the metering indicator "bar" (from -5 to +5) is from the rear LCD screen. This is rather incommodating: when you look in the viewfinder and that this "meter bar" is not there, instead, I have the "level" indicator. Not great to adjust the aperture and shutter speed!
What am I doing wrong?
Thanks.
JP
06-24-2010, 06:11 PM   #2
Wheatfield's Avatar
The level indicator precludes the metering bar, so you need to turn off the level.
I wish they could have found another way to do it.
06-24-2010, 06:19 PM   #3
Unfortunately one of the K-7's limitations.
I usually switch off the level indicator in order to show Exposure metering while in Manual exposure.
06-25-2010, 07:26 AM   #4
jpzk's Avatar
Thanks Wheatfield and Kittykat ...
I just did that and finally got the metering bar back.
Cheers!
JP
camera, dslr, indicator, k7, photography
Debug Mode Question about "AF Test Area" values brecklundin Pentax DSLR Discussion 1 06-16-2010 04:46 PM
Manual flash but "P" mode in K10D? Zakovva Troubleshooting and Beginner Help 1 03-13-2010 09:57 PM
K20d-Frame Count on panals..works w/"M" & "P" mode only? arbib Pentax DSLR Discussion 1 08-28-2009 05:47 PM
K-7 and metering with "K" and "M" lenses NaClH2O Pentax DSLR Discussion 17 07-18-2009 09:00 PM
Flash firing immediately on "2s delay" drive mode oguzgel Pentax DSLR Discussion 5 03-30-2008 01:20 PM
All times are GMT -7. The time now is 10:06 PM. | See also: NikonForums.com, part of our network of photo forums!
