06-26-2010, 08:32 PM   #1
SpecialK's Avatar
Overexposure problem...
Recently got a Sigma 150-500 (f5-6.3). Used it lightly twice at the park, and all seemed fine.
Went to the zoo and elsewhere today, and had significant but intermittent exposure problems.
Here are just a couple examples. They are extracted jpgs from the PEFs. Nothing additional, and they include the duds. Oh, and I did not rotate them either. This is only an exposure evaluation, so go easy :-)
Consecutive shots... (And I look a lot like this guy right now, but he has more hair.)
and...
Bracketing is off. No EV compensation. P mode unless I accidentally move the dials into Av or Tv. ISO 400. (The exposure values actually used probably would be good...at ISO 100 :-(
I posted 200 shots at the link below so you can see the sequence and that is it a hit or miss thing. I understand dark gorillas and white birds affect the meter - but this is beyond those effects.
Problem pictures by KylePix - Photobucket
My theory is that it's a contact thing between the lens and mount.
Note that some of the new Bigmas and these related cousins appear to have a service recall for autofocus issues and this lens falls within the serial number range - but the autofocus seems to operate normally - this is different.
This one will get exchanged or serviced, but any ideas?
(Wheatfield - I know your view on Stigmas :-)
06-27-2010, 11:18 AM   #2
Marc Sabatella's Avatar
I'm assuming you meant to post this in the DSLR or lens forum, and not PP, then? Since as noted, the exposure selected by the camera seems off - it's not a question of the slow aperture blades or something else causing the lens not to stop down correctly - it seems mostly likely to be some sort of camera issue (assuming it doens't turn out to be something silly you're forgetting, but you seme to have covered the bases in making sure bracketing is off, you're in multi-segment metering mode, have compensation off, etc - and overly *bright* exposures seldom results from an exposed viewfinder).
Anyhow, I've moved this to DSLR...
autofocus, camera, dslr, exposure, iso, lens, photography
K-x overexposure? kevingt01 Pentax DSLR Discussion 5 05-17-2010 12:45 AM
consistant overexposure dougmc Pentax Compact Cameras 3 04-21-2010 12:46 AM
overexposure with k200d? longerboats Pentax DSLR Discussion 7 10-15-2008 10:24 AM
Pentax 18-250 and k10d overexposure problem j1mallen Pentax SLR Lens Discussion 2 07-14-2008 05:11 PM
IST-D overexposure problem stwinkc Pentax DSLR Discussion 4 03-10-2008 03:24 PM
All times are GMT -7. The time now is 09:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
