06-28-2010, 04:33 AM   #1
kari's Avatar
K-x AF motor spinning
I just had a huge fright with my K-x. When I switched it on today it would not autofocus at all. The AF motor just kept spinning, like it wasn't getting any traction on the lens. On the DA L 18-55 kit lens, it seemed like it got traction but was slipping and kept spinning, moving the focus bit by bit until focus was achieved. I switched round to my 55-300 and it just spinned, getting no traction at all. So I took it off, wiped all the metal contacts, poked around a bit around the lens mount and put on the 18-55 again. Still no luck.
I then switched off the camera and turned the focus ring on the lens this way and that way while in the AF mode. When I switched on again, things were back to normal, with my 55-300 as well. Huge sigh of relief, because I'm sitting on an subantarctic island, with no ways of sending the camera in for repairs. I don't know what could have caused this, as the camera was still working fine yesterday and just sat on a shelf until I picked it up today.
Any idea what could cause this to happen? Do you think the problem will return? Should I buy a new camera and get it sent down with the next ship?
06-28-2010, 04:41 AM   #2
kari's Avatar
I was also wondering if the problem would show up on a Sigma 17-70 OS HSM. Does the in-body screw drive motor still turn or is there some other mechanism to drive the in-lens focus motor?
06-28-2010, 04:43 AM   #3
i think the focus clutch freezed up. try giggling the AF-MF switch
it's quite possible that this can happen again, and if it does, i'd check the circumstances on why it happened.
how cold is it where you're using the camera?
i've used my k10 and sigma 17-70 in 20 degree F weather and the focus went crazy. back in 70 degree weather, it started behaving again.
a new kx body may not necessarily help.
K7's are supposed to be rated to work at lower temperatures, but not the kx.
06-28-2010, 04:44 AM   #4
in-body screw drive should NOT turn on an HSM equipped sigma
the 17-70 i used was the old screw-driven version
af, bit, camera, dslr, focus, k-x, lens, motor, photography
Pentax KX Motor Ole Pentax Film SLR Discussion 1 04-09-2011 04:55 AM
My head is spinning. 16-45mm or 17-70mm or... Unsinkable II Pentax SLR Lens Discussion 10 05-16-2010 11:30 AM
Autofocus motor. NecroticSoldier Troubleshooting and Beginner Help 6 03-19-2010 08:02 AM
tripod head spinning off :( rdrum76 Pentax Camera and Field Accessories 9 01-27-2009 09:46 AM
Spinning Wheel Mike Cash Post Your Photos! 2 09-10-2007 06:28 AM
All times are GMT -7. The time now is 06:14 PM. | See also:, part of our network of photo forums!
