06-30-2010, 08:38 AM   #1
K-x and default ISO in Av mode
I finally broke down and got an nice shiney new-to-me k-x. I've already run into a minor problem. I almost always shoot in Av mode but I very much like to determine the ISO I'm using. When I turn the camera on in Av mode, the ISO reverts to auto. Obviously this is the default. I change it to manual and select the ISO I want but when I turn the camera off and then back on it is set back on the auto ISO setting. Is there any way I can make manual ISO the default setting when I turn the camera on in Av mode. I've searched the manual and can find nothing. Yes, it's a work-around problem, but my K-20D stays where I set it when I turn it off, I'd like the K-x to do the same.
NaCl(irksome it is, irksome)H2O
06-30-2010, 09:04 AM   #2
You're doing something wrong. My K-x remembers the last ISO setting when I turn it back on.
06-30-2010, 09:06 AM   #3
You can change what is remembered by the camera in the Memory menu : Menu-> Rec 4 -> Memory
06-30-2010, 09:33 AM   #4
QuoteOriginally posted by dlacouture Quote
Thanks! That did the trick. I guess I should read the manual again :sigh:
NaCl(anybody else suffer from CRS? )H2O
auto, av, camera, default, dslr, iso, k-x, mode, photography
Default ISO 200 vs ISO 100 joodiespost Troubleshooting and Beginner Help 6 01-09-2010 05:50 PM
ISO in Manual Mode campdog Pentax DSLR Discussion 4 11-24-2009 12:29 PM
Change Default Values in GREEN mode brosen Pentax DSLR Discussion 5 10-12-2009 07:05 AM
What drive mode do you set on default? Luciferase Photographic Technique 32 04-05-2009 07:38 AM
ISO in manual mode dustartist Pentax DSLR Discussion 16 03-21-2008 06:27 PM
All times are GMT -7. The time now is 12:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
