07-04-2010, 03:39 PM   #1
[langtitle=sv]k10d - can i adjust green-button-exposure measuring?[/langtitle]
I have an old rikenon 50mm/2 P which I'm happy with,
and use the manual mode with "green button" for exposure measuring.
However, the k10 always underexposure with about 1/2 - 1 step.
So I've aquired a habit of increasing the suggested exposure-time,
which works but it's tedious.
Since EV-adjustment isn't available in M-mode, I'd like to trim the
exposure-measurement in any way. Possible??
regards,
/teson
07-04-2010, 04:55 PM   #2
Lowell Goudge's Avatar
Unfortunately no. For some reason the k10 is the only camera that does not have ev compensation in manual. It drives me nuts
07-04-2010, 05:39 PM   #3
Why do you need EV compensation in M mode? Why not just dial in the correct exposure?
Set your custom menu to do DOF preview (not digital preview) when you pull the power switch to the right (preview position) to stop the lens down, and then dial in your exposure according to the meter. If you find you are still under exposing, adjust accordingly.
07-05-2010, 12:51 AM   #4
[langtitle=sv]solved[/langtitle]
I browsed the handbook and the Av-mode mode works with my rikenon,
it does however always measure and expose on minimal aparture, 2.0.
So Av-mode for 2.0, "M" for anything else.
And no more need for green-button and EV is back.
:-D
//t
07-05-2010, 05:36 AM   #5
QuoteOriginally posted by JeffJS Quote
Why you ask?
Because many lenses exhibit a metering error that is consistent over most or all of the aperture range. In this case you would want to dial it in once not every time you meter on a scene. As I pointer out earlier the K10 is the only camera that does not allow ev compensation.
If you want an example of a lens and metering issue just put a teleconverter on a lens with an A setting and watch what happens
07-05-2010, 07:41 AM   #6
Why you ask?
Since I don't own an A type TC, that amounts to putting an M type lens on the camera. I put the lens on the camera, set to M, pull the DOF lever, and There is the meter. Adjust the exposure (which you have to do in M anyway), focus, and shoot. If you know a particular lens ALWAYS underexposes anyway, press the green button, adjust aperture or shutter speed, focus shoot.
I understand that some would rather not take that extra exposure step and would prefer to just use the green button, but it isn't that much of a hardship to do it.
07-05-2010, 08:44 AM   #7
Marc Sabatella's Avatar
It's especially non-problematic if you get out of the habit of hitting the Green button on every shot, but get comfortable with simply letting an exposure ride until the light changes.
But FWIW, the K10D is *not* the only model that doens't allow compensation in M mode. It may be the only *two-dial* camera that doesn't, though.
07-05-2010, 11:03 AM   #8
It is a problem more when shooting wild lifemwith long lenses and in and out of shadows
While Marc manly be correct withrespect to other single wheel bodies also not having the feature it really is an oversight on pentaxes part
07-07-2010, 06:39 AM   #9
Thanks guys for the info. Very iteresting. I have not play a lot with manual lenses. Any info is very helpful.
07-07-2010, 08:39 AM   #10
Also wider angle shots when walking through the woods with dappled light where you're constantly going in and out of shadow. These two situations are actually about the only times I ever consider leaving M mode (assuming I'm using a lens that supports other modes). But I do think many people probably hit the Green button unnecessarily often overall.
camera, dslr, photography
ufraw ubuntu red is green kjells Digital Processing, Software, and Printing 18 11-05-2010 08:56 PM
A long time exposure strange phenomenon current Pentax DSLR Discussion 7 06-08-2010 09:18 AM
Exposure comensation on A3(000) KjetilH Pentax Film SLR Discussion 1 06-03-2010 06:15 AM
Pentax K110D shutter release button fault? bogner Pentax DSLR Discussion 0 12-23-2009 09:09 AM
K10D Exposure w/Green Button in M mode carpents Pentax DSLR Discussion 28 04-28-2007 05:46 PM
All times are GMT -7. The time now is 07:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
