Originally posted by JCSullivan Thanks Ole, I remembered you had the istD and was hoping for an answer.
Where do you have your Mode Dial set to???? I have mine on the Green Auto and should probably have set to P or Av - what do you think.
Do you actually have to keep the button down and shoot 3 shots??? Should the camera take only one shot and make the adjustments by itself??
Thanks
I usually use P mode. When you have set the bracketing you can let go of that button. The camera will stay in bracketing mode until you press the button again and turn the e-dial one click to the left.
You can keep the shutter down until all three photos have been taken, or you can click three times in a row. You can see in the finder how many photos of the bracketing sequence are left to take: Initially there are three small bars on the exposure scale to the right. They show at which EV compensations the shotts will be taken. As you take the shots, the bars disappear one by one. When you again see three bars that's when the bracketing cycle was complete and you're ready for the next set.
