11-29-2006, 12:44 PM   #1
Manual focus lens and K10D
Hi,
Am I doing this right? When using an old screw or K mount lens I set the mode to "P", pick the aperture I want, focus until I get a green light and beep. No need to do anything else because the shutter speed is automatically selected. This seems to work but I keep reading you must push the green button for stop down metering?
regards,
Ken
11-29-2006, 01:04 PM   #2
With the screw mount lenses, yes.
With K and M lenses, it shoots the lens wide open using your method. You need to press the green button to stop it down (and shoot in M mode, too.) It is actually a little better implimentation than on the other models because the button is right next to the shutter.
This is one of the reasons why I started buying the old Takumars. I keep on buying them because they're awesome.
11-29-2006, 01:19 PM   #3
Thanks!!! So with the K mount "A" lenses if I have it set to "A" and P mode, all I have to do is focus?
Regards,
Ken
11-29-2006, 01:32 PM   #4
QuoteOriginally posted by regken Quote
Regards,
Ken
Yup - with A, FA, and DFA lenses set to the 'A' position you can control the aperture fully in P mode.
11-29-2006, 02:06 PM   #5
Ole
Ole's Avatar
Hi,
regards,
Ken
Make sure the lens is set to manual aparture or else you'll be shooting wide open.
11-29-2006, 03:23 PM   #6
Thanks Ole!
Just one more little detail I missed. This thing is much easier to use than I ever hoped for. Now if the weather will turn to something other than flat gray I might be able to get some good shots.
Regards,
ken
camera, dslr, focus, focus lens, lens, photography
K-5 Manual Lens Front Focus & Focus Beep woes fixed kneonx Pentax K-5 & K-5 II 14 04-12-2014 03:47 PM
Can a manual-focus lens have back focus problems? PocketPixels Pentax DSLR Discussion 33 02-13-2011 05:37 AM
manual focus lens into AF? SebastianP Pentax SLR Lens Discussion 19 11-03-2010 09:46 AM
Manual focus issue with K10D Tall Guy Pentax DSLR Discussion 24 04-28-2010 03:04 AM
Manual focus problem with K10D? yyyzzz Pentax SLR Lens Discussion 8 12-01-2009 05:50 AM
All times are GMT -7. The time now is 11:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
