07-12-2010, 06:20 AM   #1
Film Plane/Sensor Face
I'm currently using a Model K110 and a K100D Super.
Were on these camera bodies would represent the film plane or the sensor face?
The old 35mm cameras usually had these reference planes marked the body.
Thanks
Bert
07-12-2010, 06:27 AM   #2
Wheatfield's Avatar
45.46mm back from the lens mount.
07-12-2010, 06:31 AM   #3
Wheatfield,
Thanks for the speedy reply, greatly appreciated.
Bert
07-12-2010, 08:39 AM   #4
Thanks for the info. I also was wondering this.
07-12-2010, 09:52 AM   #5
Marc Sabatella's Avatar
You can also see the sensor directly if you put the camera in sensor cleaning mode (which flips the mirror up).
BTW, is there a reaono you're wondering?
07-12-2010, 03:36 PM   #6
The K-7 has a sensor plane reference mark on the top plate to the right of the LCD. These reference marks started to disappear from cameras in the 1970s. My Ricoh Singlex TLS has one as does my Mamiya/Sekor 1000 DTL (both about 1969-70). My Pentax KX (1976) does not.
07-15-2010, 07:49 AM   #7
Stevebrot,
Am trying to set these cameras up to check the front and rear focus.
I thought the more accurate the camera was set-up the better the results would be.
Thanks for your interest, any further input would be greatly appreciated.
Bert
07-15-2010, 09:32 AM   #8
I can't imagine any valid way of testing focus that would care in the slightest where the sensor plane is.
07-15-2010, 11:10 AM   #9
QuoteOriginally posted by brieck Quote
Stevebrot,
Bert
I think maybe you wanted to direct your comment to another user. I agree with Marc, however in wondering how you would use the sensor plane in a focus test.
As for how the index mark has been traditionally used...That one is fairly easy. For macro work, knowing the exact distance and the focal length allows calculation of the size of an object being photographed.
07-15-2010, 11:45 PM   #10
smigol's Avatar
I believe that knowing the location of the sensor plane helps with controlling parallax effects with doing panoramic shots. If you had a camera that had the mounting point offset from the film/sensor plane, if you snapped a panorama, you could have double images as the view would shift through the movement.
Software has helped this process quite a bit over the years.
07-16-2010, 06:51 AM   #11
Wheatfield's Avatar
QuoteOriginally posted by smigol Quote
Actually, you need to know where the rear nodal point of the lens is, as you need the camera to rotate around that for perfect panoramics.
In practice it isn't that big a deal though.
07-16-2010, 07:04 AM   #12
Lowell Goudge's Avatar
except that this is only correct for a simple lens, not the complex optics of today.
It is probably much more accurate to know the subject to front element distance, and focal length than the focal plane location and focal length.
THis is especially true for true telephoto lenses, and recall telephoto by definition is not a lens longer than 50mm, but a lens with an effective focal length that is longer than the physical length of the lens.
07-16-2010, 08:09 AM - 1 Like   #13
RioRico's Avatar
On the K20D, ~45.5 mm from the lens mount (the nodal point for pano shots) is at the back of the flash shoe. The center of the tripod socket is ~38mm from the mount, so some sort of adapter (I made a cheap one from angle brackets etc) is needed to fix tight pano parallex problems. I'll echo the above -- with modern optics, I don't see other significant operational reasons for knowing where the sensor plane is. But maybe I'm just uninspired.
07-16-2010, 09:16 AM   #14
smigol's Avatar
Of course! I forgot about the way that the rays would cross as being the pivot point.
07-16-2010, 08:12 PM   #15
Ummmm...that is interesting.
I was basing my comment on the closeup tables that were included in the instructions for Pentax-brand bellows. Focal plane to subject distance was one option for determining magnification using the table. A different table was supplied for each focal length. (See http://www.pentaximaging.com/files/manual/Auto_Bellows-M__Slide_Copier-M.pdf)
camera, dslr, film, photography
People The Face of a Newbi is a face only a mother could love :) Borislav Post Your Photos! 2 04-23-2010 12:36 PM
Could a Fuji Film Sensor be in Pentax's Future? mithrandir Pentax News and Rumors 21 02-26-2009 08:46 AM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
plane wildherre Post Your Photos! 3 03-19-2007 11:10 AM
All times are GMT -7. The time now is 07:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
