Originally posted by Rico I think the K-7 is a total success including higher ISO performance with some minor faults. The K-7 did away with the blue chroma noise in high ISO images produced by the K20D. The K-7 high ISO performance has a much more pleasing film grain look than the K20D. In no way do I see the K-7 high ISO performance as a step back from the K20D. It is not leaps and bounds better but it is a clear improvement over the k20D.
Actually it is quite strange tbh, but when the K-7 came out, I also felt this way about nominal IQ and pixel definition. But a closer examination showed that much of the K-7's output was due in part to it's processing settings. And that it was quite possible to match and even exceed its output by adjusting curve and sharpening settings in the K20D.
However, it wasn't until GordonB came out with the K20D Tinge Removal Utility(which virtually eliminated magenta tinging) That the K20D took a major leap in NR performance over it's successor. And once we coupled this with ACR'd latest demosaic engine, it would become the best high ISO RAW performer next to the K-x.
So what does this all mean?
Well... since the K20D initially held a marginal advantage over the K-7 with regards to noise performance. We now have a series of improvements that would give it the ability to produce uncompromized(black & reductions, resizing, etc). ISO6400 images. In contrast to the K-7 which usually begins to demonstrate(what we could call) difficult noise artifacts(ultra low frequency noise ) as early as ISO2400.
For what it's worth... I find DPreview's K20D/ K-7noise tests a little misleading for the following reasons:
1. The K-7 has a superior JPG and NR engine over the K20D.
2. The noise image samples are too small too assess artifacts such as low frequency noise.
3. The graphs do no reflect real world contrasts of how a 10% noise curve impacts output.
Despite all this, there are enough high ISO samples here to see first hand where each unit stands with regards to sensitivities and image quality.
Having said all that! - Noise performance is but a small part of the picture. The truth is, it's not as empirical as many would think! For example; the K-7 may very well be(what we could call) the single largest performance and feature upgrade ever made in Pentax history! And personally, I just can't wait to see what they will bring this year knowing whats available and what can be done. I think we may very well be looking at the next K20D!
