07-13-2010, 11:43 AM   #1
oshiva's Avatar
power fails on K10D
Hello
I have a strange problem with my K10D
the power fails 90% of the time
when I gently finger the release-button, then the power comes back on, for a while,
as if it were in stand-by sleeping mode (which it is not)
It is now to troublesome to go on a shoot, and repair could cost up tp 300.... pfff
Is anyone familiar with this problem ?
07-13-2010, 01:18 PM   #2
I assume that you have proven out (eliminated) your battery and battery connections?
07-13-2010, 01:39 PM   #3
oshiva's Avatar
yes, certainly, batteries and -connections are fine
07-13-2010, 06:16 PM   #4
Otis Memorial Pentaxian
Mine does this all the time. The behavior is intended. I think they refer to it as "Auto Power Off" (battery saver) mode. See page 198 in the K10D manual for instructions on how to customize this feature.
P.S. You can download the manual HERE.
07-14-2010, 12:40 AM   #5
oshiva's Avatar
yes, you can actually adjust the time until it goes on stand by. Mine is on 5 minutes.
I've tried a reset (to factory settings), but the erratic behaviour remains, especially after taking a photo.
07-14-2010, 11:54 AM   #6
The default (factory) setting for Auto Power Off is 1 minute. You should turn it completely off and see if your camera still continues to power down.
One other thing to consider...Is your K10D battery dying? Lithium cells have a finite life from date of manufacture. Most start to get a little flaky at about 3-4 years. That life can be shortened by frequent full discharge or being maintained in a partial discharge state. My K10D is about 3.5 years old and I figure it is probably time to replace the battery.
07-15-2010, 01:16 AM   #7
oshiva's Avatar
I will turn off the 'auto power off' tonight when I get home.
But I'm afraid it's a mechanical problem i.e. costly....
07-15-2010, 11:50 PM   #8
smigol's Avatar
You wouldn't happen to be using a MODSET file? I've noticed strange power behavior when having one of these files in place. A format of the card done in the camera cleared it up for me.
07-16-2010, 12:43 AM   #9
oshiva's Avatar
I cannot imagine, but will try (anything). I've been using the same 4-gb card over the past half year. It should contain nothing but jpg's and raw's.
(will check tonight)
09-04-2010, 02:46 PM   #10
oshiva's Avatar
And all of a sudden the camera is back to normal...
Would be nicer if I understood, but hey, I'm very happy !
camera, dslr, k10d, photography, power
Hitlers SDM Fails knumbnutz Pentax SLR Lens Discussion 25 04-11-2010 08:17 PM
Misc When all else fails....... 68wSteve Post Your Photos! 3 02-05-2010 12:11 PM
Power Zoom lens on a K10d HeavyD Pentax SLR Lens Discussion 4 07-20-2009 03:49 PM
Ppg fails yeatzee Photo Critique 2 07-17-2009 10:37 PM
Help K10D Will not Power on !!! daacon Pentax DSLR Discussion 31 12-11-2007 12:35 AM
All times are GMT -7. The time now is 12:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
