07-15-2010, 11:11 PM   #31
This is more likely due to in-camera jpeg settings and/or the lens quality.
07-15-2010, 11:42 PM   #32
I'm pretty sure my DA* 50-135 is up to the challenge
Occasionally I'll get it right and the photo comes out well, but most of the time it looks like I took it with a camera phone.
07-16-2010, 04:23 AM   #33
There was a big thread about Pentax's "dull" colors. The only thing that I can say is that you probably need to work on your post processing skills a little. You can really bump up the saturation when shooting in camera jpegs with the K7, but if you take photos of people much, it tends to make skin tones look odd. Better to do it after the fact with the vibrance slider in ACR.
07-16-2010, 05:23 AM   #34
GeneV's Avatar
And the same goes for NR and sharpening. However, as was discussed in many other threads, a few minutes in the menus, and you can get flourescent colors from a Pentax camera jpeg as well.
07-16-2010, 08:00 AM   #35
dadipentak's Avatar
Oh, and in case you're not in the habit of doing so, do use lens hoods--it can make a big difference.
07-16-2010, 11:27 AM   #36
Marc Sabatella's Avatar
QuoteOriginally posted by sebberry Quote
You'll have to post an example if you expect anyone to believe that. And in case case, so many image processing settings are customizable there's really no reason you can't get whatever kind of results you want.
07-16-2010, 11:43 AM   #37
Sometimes I nail it just right like this
or
And then I'll get photos like
and
Right click, open in new tab. This forum screws up the links...
07-16-2010, 11:46 AM   #38
yeatzee's Avatar
Basically I was considering the upgrade because many of my photos come out rather "flat" or dull looking in terms of colour saturation. They generally lack the bright, rich "punch" that I have seen from newer cameras. Then again, I have seen some pretty flat looking photos from the K-7 as well.
Everyone post processes their images... your supposed to! The newer camera images you've seen are processed I garuntee it.... that or they are Jpeg and the settings are boosted to max
edit: your going to need to post larger sizes than that
07-16-2010, 11:53 AM   #39
That's odd, they're thumbnails and should link to bigger versions
07-16-2010, 11:55 AM   #40
yeatzee's Avatar
The thumbnails do not link to larger images
07-16-2010, 12:00 PM   #41
Ok, there's something screwy with how this forum displays images.
It should work now unless it broke the links again. It was opening the thumbnail in a new tab, then opening the full version in another new tab...
07-16-2010, 12:07 PM   #42
07-16-2010, 12:17 PM   #43
And then I'll get photos like...
Well, sure if the scene really *is* flat, then of course the image won't have the same kind of pop. Part of the skill of photography is picking the right scenes - the camera isn't going to magically take a flat scene and make it not flat (and if it does, then it's defective - a camera is not supposed to lie like that). i think you're simply being fooled by seeing images from other cameras that happen to be of more dynamic scenes in the first place. As you're seeing, though, when faced with a good scene, you camera does just fine. Faced with a blah scene, any camera will take a blah picture.
07-16-2010, 01:06 PM   #44
As above, I'm not sure what you were looking for in the second two images. I can't see any real camera deficiencies.
07-16-2010, 02:30 PM   #45
benjikan's Avatar
I love using my Pentax K10D. When I started looking at cameras I hadn't even thought of Pentax until I picked it up in the store. The controls, the body and even the lift and turn levers for the battery and SD doors that are reminiscent of the old film winding cranks made me fall in love with the camera.
Trouble is, I can't seem to take a decent photo to save my life. While I realize it comes down to the photographer and not so much the equipment, I tend to see better images from the K20D and even better ones from the K-7.
I have no desire to get rid of the K10D. After all I do have a DA* lens and the K10D is the only camera I can flash back the firmware to a screw-drive for the * lens.
But the improved IQ and low light capabilities of the K20D/K-7 are tough to resist.
I am more partial to the K20 since it is bigger, the K-7 is nice but I can't stand the cheap SD door and rubber cover over the USB ports.
Where was the bigger jump in IQ and high ISO performance? Was it from the K10D to the K20D or was it the K20D to the K-7?
Ummm...I'll keep it short and to the point. The reason I stay with the K20D over the K7, is I prefer the output of the K20D over the K7.
That's all folks.
Photo Below Pentax K20D + Pentax Ltd 40mm
camera, dslr, iq, k-7, k10d, k20d, lens, love, pentax, photography, sd
Buy the K20D user manual Malsi Pentax Camera and Field Accessories 6 08-28-2009 05:31 PM
K20D--Buy now or wait Shaws1 Pentax DSLR Discussion 43 02-19-2009 09:02 PM
Should I buy a K20D Or Keep K10D? Longboarder Pentax DSLR Discussion 26 01-02-2009 03:07 AM
Best Buy and K20D Bob Tuttle Photographic Technique 3 03-22-2008 07:10 AM
Why you shouldn't buy a Pentax K20D! ebooks4pentax Pentax DSLR Discussion 48 02-06-2008 08:56 AM
All times are GMT -7. The time now is 07:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
