07-15-2010, 08:25 PM   #1
jeffshaddix's Avatar
Cleaning LCD for Screen Protector
What's the best method for cleaning the top and bottom LCDs on my K-7 before I apply my ACCMAX screen protectors?
I was thinging a 50/50 solution of rubbing alcohol/water and using my eye glasses cloth to wipe it clean, Or perhaps I could just use the same spray solution I use to clean my glasses? Any tips?
Thanks!
07-15-2010, 08:41 PM   #2
Banned
Straight rubbing alcohol (which is usually only 80% anyway) should be fine, just use sparingly with a lint free cloth.
07-15-2010, 08:54 PM   #3
The stuff you use to clean your glasses may have an anit-fog agent. Just use a mild detergent (sparingly, to remove the grease from fingerprints and cheek and nose prints), rinse it clean with a damp cloth, and then dry it. It's a piece of plastic.
07-16-2010, 04:48 PM   #4
The best and safest is to use standard lens cleaner and lens cleaning paper. It will take oil and most anything off and will not scratch or remove any protective coatings that may be applied.
camera, dslr, glasses, photography, screen, solution
K-7 LCD screen protector LeDave Pentax Camera and Field Accessories 11 11-07-2009 10:33 AM
Acmaxx 3.0 lcd screen protector mba1971 Pentax Camera and Field Accessories 2 11-05-2009 04:23 PM
LCD screen protector for K10D heatherslightbox Pentax DSLR Discussion 21 02-16-2008 08:55 PM
LCD Screen Protector squarerigger Pentax Camera and Field Accessories 9 03-26-2007 09:14 PM
K10 lcd screen size for protector k10user Pentax DSLR Discussion 4 12-10-2006 07:21 PM
All times are GMT -7. The time now is 06:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
