Originally posted by SpecialK Sorry I can't help you. Oh, the little rubber eyepiece is 29.99. Actually silicone says pretty flexible so you should be able to dig it out if needed.
Yeah - thinking of just plugging the center-hole where the plug-pin inserts with a cropper toothpick, and pressuring silicone into the outer cavity where the threads are. With a bit of luck, this process should end up creating a little threaded silicone cap that I can remove—and replace—with little/no problem.
Originally posted by Wheatfield If it makes you feel any better, cameras weren't weather sealed for a very long time prior to this, and seemed to keep working.
Agreed - I wouldn't be too paranoid about it if I wasn't as enthusiastic about using this camera in the pouring rain, which I've done numerous times (including the evening I purchased it), without mishap or anxiety. The weather-sealing and field-reports of people using the k-7 & k20d in harsh conditions successfully were the main reason I ended up with one. That said, given the very limited opportunity for water to ingress through the pc-socket, I'm comfortable sealing it up whatever way I can—duct tape, silicone, another cap, etc., as long as it's covered.
Originally posted by JeffJS The Nikon one won't work, I'm pretty certain: Nikon sync ports have a wider thread to accommodate their threaded PC flash sync cables. Given that the threading on these cables is too wide to thread into my K-7 (trust me, I know this because I've tried, and am frustrated by the incompatibility), the same must also be true of the port covers.
Unfortunately I've had no luck on ebay finding pentax sync caps, save for one oem cap being sold by B&H, who won't ship to Canada
Originally posted by nanhi Hey Tchango, change things a bit my friend. And you have the knowledge too. But please don't paste that synchro socket shut for good - that's sacrilege man.
Here's good advice from a DIY Master Mechanic: look around for small cap like things in the home and medical shops. Softer plastic ones will let you thread them in by self forming the thread. Then take it out again, apply just a wee bit of rubber solution - your local cycle shop will give you a drop for free - used for punctured cycle tubes.
Homeopathic medicine bottles have a large variety of caps, as well as eye drops, and small pain balm tubes. Come on plastic moulder friend, use some imagination.
Just use a hobby knife to shape a small cap, just don't cut off the close end. Cut a little step and smooth off with emery so that it fits the thread a wee bit tight to start off. And caps are knurled too for grip. Happy hunting.
Definitely some other options here, but just wanted to exhaust the possibility of finding a compatible 'manufactured' cap first
Originally posted by Wheatfield That sounds like spending $25.00 to save $20.00.
Just order the part from a camera store. That way you get an OEM part and the store covers shipping.
I'm definitely going to look into this... I wonder if the retail price might be marginally better as well...
