07-19-2010, 05:21 PM   #1
Non-P-TTL AF Flash
Will older non-P-TTL AF (auto focus) flashes work in auto thyristor mode (flash has own sensor) on a K100D? The flash will be Pentax dedicated. The real question is will the auto focus assist work? Has the hotshoe pinout for AF changed from film to digital? I realize I have to manually set aperture and shutter speed. I am also aware of trigger voltage limitations.
07-19-2010, 07:43 PM   #2
GerryL's Avatar
From what I have read..'coz I don't have a direct experience with this but wanting to buy one before because of the AF assist light is that as long as it is a Pentax brand flash, it would work.
A lot of members here are using the very popular AF280T with swivel and bounce for the auto-thyristor factor and some are using another Pentax model flash (model number I always forget) for the AF assist function.
The AF280T doesn't have the AF IR light but has the bounce and swivel and auto-thyristor as a come-on that's why it is so popular.
07-19-2010, 10:08 PM   #3
Hi trailrider,
I have an AF 500 FTZ and a AF 280T. The 500 has an SB that works in Manual mode, but no Auto Thyristor sensor, and no P-TTL. The 280 has Auto Thyristor mode, but no SB light and no P-TTL. You might try looking up the owners manuals for the other AF flash models, as Pentax at least used to have them all available for downloading. The older ones are pretty bad copies, but they're readable -- and notoriously sparse in information, but you should at least be able to get a feature list.
07-19-2010, 11:45 PM   #4
QuoteOriginally posted by trailrider Quote
From my experience with old third party flashes: yes, the auto focus assist will work, no, the pins have not changed. Which flash are you thinking of using?
Thank you
07-20-2010, 12:52 AM   #5
nanhi's Avatar
Hi Trider, my Quantaray QB-6500U flash works very well with the PK AF Module in the non PTTL mode. The Red focus light throws a bright patterned light far away too.
With the Promaster 5050DXR Module it becomes a PTTL Flash on my K20D. With the Quantaray Manual Module it becomes an Auto Thyristor Flash with the "magic eye".
These are good cheap Flash Guns with lots of flash power. Many other similar makes are also available. See a test shot attached.
07-21-2010, 06:04 PM   #6
Thanks for the replys!
I was looking at some older Sunpak AF flashes 400, 4000 and 5000 series. I did find the manuals and they seeemed to only work with Nikon AF. I just bought a Sunpak 433D. It does not do AF assist but has a 120 GN. I was just looking for something not too big with some power and additional height to reduce red eye. I also have a Metz 45 CT-3 when I am not worried about size.
af, auto, camera, dslr, flash, focus, photography
Difference between TTL and P-TTL flash. rod_grant Pentax DSLR Discussion 46 11-15-2017 10:05 PM
Please Help with AF500FTZ TTL flash highhog1 Troubleshooting and Beginner Help 21 01-13-2011 01:42 PM
TTL - P-TTL flash? axl Pentax DSLR Discussion 8 10-27-2007 08:50 PM
*Ist DL and TTL flash Matjazz Pentax DSLR Discussion 28 01-15-2007 08:09 PM
All times are GMT -7. The time now is 12:47 PM. | See also:, part of our network of photo forums!
