07-19-2010, 08:10 PM   #1
K-x and Infrared
I recently picked up a 720 nm IR filter, and have been experimenting with it. My biggest problem is exposure. Just how red are my pics supposed to be (pre-processing)?
So far, as an example, on sunny days, I can get satisfactory (to me, anyway) photos using my 55-200mm of 1/2, 0.4, 0.3, 1/4, & 1/5 sec, @F5.6, 115 mm. On cloudy days I seem to be upping that to around 1-3 seconds.
Anyone else trying IR that can share some information?
07-19-2010, 08:28 PM   #2
RawheaD's Avatar
The rule of thumb I got from somewhere and have been using is that looking at the histogram, it should look slightly underexposed (the curve peaking towards the left of center).
07-20-2010, 07:52 AM   #3
jwiles's Avatar
I found a good reference for how pics should/can look using filters is the Cokin site. www.cokin.com
07-20-2010, 05:58 PM   #4
Ex Finn.'s Avatar
All should be red, you are mainly letting in the long=red wave lengths, heavy pp is normal.
07-20-2010, 06:49 PM   #5
alohadave's Avatar
I don't know about the K-x, but the K100DS has a really weak IR filter, and I do 4-8 seconds in full noon sunlight to get good exposures.
You want to get the histogram as far to the right as you can without blowing out the red channel. If you underexpose at all, you'll be amplifying noise in all the channels when you process.
Everything will look red because the filter removes everything above 720nm which is deep red, into near-IR. You can either go B&W, or swap the red and blue channels (there are tutorials online) to get blue skies back. You can also get funky color effects by setting custom WB off various tones in the picture.
camera, days, dslr, ir, photography
Misc Three in infrared xs400 Post Your Photos! 8 02-14-2010 09:18 AM
K7 and Infrared therion Pentax DSLR Discussion 0 07-19-2009 02:19 AM
Infrared Nestos Post Your Photos! 1 07-10-2009 01:24 PM
Two Infrared xs400 Post Your Photos! 5 03-11-2009 01:42 PM
More Infrared khardur Post Your Photos! 18 08-24-2007 04:12 PM
All times are GMT -7. The time now is 09:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
