07-19-2010, 09:45 PM   #1
Dubesor's Avatar
AF-330FTZ Flash - Compatible?
Is AF-330FTZ a good flash model for Pentax DSLRs? I don't usually use flash in my photography so am quite clueless about them. Would it still have all of its features available when plugged into my K-x? Or my friend's *ist D? Is its voltage safe for use on these digital bodies?
This is the model I'm asking about: PentaxForums.com Pentax Accessory Review Database - Flashes, Grips, Camera Bags - PENTAX AF 330FTZ
PS How about on a Pentax 645? Is this a usable flash for my medium format camera?
07-20-2010, 04:23 AM - 1 Like   #2
This flash should work in auto mode on 645 bodies, as they support TTL.
On all DSLRs with the exception of the *ist D and *ist DS2, it'll only work in manual mode. Pentax decided to cut costs with the newer bodies, and therefore, only P-TTL is supported, rather than both TTL (which requires an additional light meter installed inside the camera) and P-TTL (which is software-based).
07-20-2010, 05:09 AM   #3
Lowell Goudge's Avatar
the AF 330 FTZ and it's big brother the AF500FTZ both work on the *istD and DS cameras as these cameras support TTL flash
Sadly, these were the last DSLRs to support TTL flash and all newer cameras these flashes will not work other than in manual mode as they do not have internal flash sensors for working in auto mode
07-20-2010, 10:00 AM   #4
Dubesor's Avatar
thanks, that's great advice. am i right to assume every flash that supports TTL will be good on the 645 camera? (in case i want to upgrade)
07-20-2010, 05:22 PM   #5
Dubesor's Avatar
also wondering how the AF160 flash compares (for the same cameras - *ist D, K-x, 645)
08-21-2010, 03:29 AM   #6
Dubesor's Avatar
I'm not really sure how to work it in manual mode, there are TTL / MH / ML settings when I press the MODE button. However, it reverts to TTL when I half-press the shutter button. How can I use this model with my K-x?
af-330ftz, camera, dslr, flash, model, pentax, photography
For Sale - Sold: Pentax AF-330FTZ Flash tsiklop Sold Items 7 12-13-2009 06:08 PM
Is the Metz 58 AF-1 Flash Compatible with K2000/KM? lawsonstone Pentax DSLR Discussion 3 06-07-2009 02:05 AM
*ist D + Twin 330FTZ flash ?? thomas81 Flashes, Lighting, and Studio 1 01-31-2009 06:41 PM
All times are GMT -7. The time now is 05:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
