07-22-2010, 10:53 AM   #1
Pentax K2000 No Manual Control
I'm experiencing a weird problem lately with my camera and auto lenses. If I set the camera to Aperture or Manual on the dial, often I can't change the f-stop and/or shutter speed. I'm about to reset to factory settings to see if that helps. Has anyone else had this issue?
I'm running firmware V 1.11.
Greg
07-22-2010, 12:31 PM   #2
tenpointnine's Avatar
Do you have a battery grip fitted?
If so, check that the front and rear dials on the grip aren't sitting between the detents.
This can cause the ones on the body to be unresponsive.
07-22-2010, 01:12 PM   #3
wlachan's Avatar
K2000 takes no add-on grip, mine doesn't at least.
07-23-2010, 04:57 AM   #4
As Alan said, no grip. I tried restoring the basic and custom values back to factory and removing the batteries - no go. Manual and Aperture priority do work for my FA 50 1.7mm. But not for my DA 18-55mm and 55-300mm.
The camera is less than a year old. I hope it's not broken. I have taken good care of it.
07-23-2010, 05:27 AM   #5
If it works with some lenses but not others, it sounds (to me, at least) like the problem could be in the lenses or, more likely, the contacts between the lens & mount. I don't know exactly what all of the pins do, but maybe one of them determines if the lens in use is a "D" (digital) lens and tells the camera how to behave.
If it were me, I'd first check that all of the pins on the mount are clean of debris and move freely. Even if they look clean, run over all of them with a Q-tip dipped in isopropyl alcohol (you can get 91% at most Walgreens or CVS stores - that's what I've always used for cleaning these types of contacts).
Failing that, I'd try to find a shop that carried Pentax DSLRs, take it in and very kindly ask if I could try a few of their lenses (other D and non-D lenses) on my K2000 and also try my lenses on one of their camera bodies to try and establish some logical pattern of behavior.
07-23-2010, 06:20 AM   #6
Thanks for the responses. What I have found is that I can control the shutter but not the aperture for D lenses. I'll try cleaning the contacts.
02-01-2011, 11:54 AM   #7
The camera was broken and serviced under warranty.
camera, dslr, pentax k2000, photography
full manual control with fader ND? karl79 Video and Pentax HDSLRs 3 02-16-2010 10:53 AM
Manual ISO Control for the K-x (a theory) johnnybodybags Video and Pentax HDSLRs 4 02-06-2010 05:55 PM
nikon d3S have hidden manual control in video, does pentax also have??? kmlo1984 Video and Pentax HDSLRs 5 01-15-2010 12:51 PM
Can the K2000, K200D, or K20D use all pentax manual lenses? Abstractational Troubleshooting and Beginner Help 20 09-15-2009 09:50 PM
Need some help: K-m/K2000 and manual lens grishazzz Troubleshooting and Beginner Help 19 04-22-2009 04:19 PM
All times are GMT -7. The time now is 10:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
