07-23-2010, 10:30 AM   #1
Can't upgrade my firmware
my k-x says i am using 1.0 so i downloaded the newst one and when i go to install it .. it just sits on a black screen forever .. i even let it set for like 30 minutes
07-23-2010, 10:47 AM   #2
jwiles's Avatar
QuoteOriginally posted by jupzchris Quote
I just upgraded mine and it went without a hitch and seems to have helped the battery level indicator issue. Did you contact Pentax? They have great on-line chat support. I've used them a few times and they have always been great help.
Here's the link... http://www.pentaximaging.com/support/live-chat/
Last edited by jwiles; 07-23-2010 at 10:52 AM. Reason: Added Pentax on-line support link.
07-23-2010, 01:12 PM   #3
Assuming you didn't brick the camera (it still works), you're probably doing it wrong. Copy the BIN file (make sure you have the one for your Kx) to a Formatted (empty) card. Make sure you have charged batteries installed. Put the card in the camera and while holding the Menu button, turn on the camera. You should see a yes/no question to update the firmware. Select yes and then Touch NOTHING until it completes (it will say so and the card access light will blink). That should be all there is to it.
07-23-2010, 02:36 PM   #4
jimH's Avatar
QuoteOriginally posted by JeffJS Quote
And make sure that you copy the BIN file to the root directory of you SD card, not into the DCIM folder, the camera won't find it there. Copy the file so that you see both the DCIM folder and the BIN file side by side in the directory.
07-23-2010, 02:36 PM   #5
hcc
hcc's Avatar
There have been previous posts highlighting that the batteries must be fully-charged to perform the firmware update with the K-x.
Make sure that you have good quality, fully-charged batteries before starting the update.
07-23-2010, 02:46 PM   #6
QuoteOriginally posted by jimH Quote
You are correct but that's why I said Empty. Of all the problems people have updating the firmware, having the BIN file in the DCIM directory is the most common cause. If the card is empty, there's no DCIM directory to confuse things. Either way, it works (or should).
07-30-2010, 07:37 AM   #7
Make sure you have the correct file. In the case of the upgrade for a K20D (I do not have a KX) you need to download the file, then unzip it. the copy the BIN file and the Readme.txt (per instruction) to an Empty SD card. then follow the instruction. Good luck.
07-30-2010, 08:05 AM   #8
How do you check the firmware that you have? I tried googling it, but all I get are a bunch of sites announcing the new firmware. Thanks.
07-30-2010, 10:21 AM   #9
jimH's Avatar
Checking firmware version
On my K10 I hold down the "menu" button while turning the camera on and the version number is displayed on the rear screen.
07-30-2010, 07:37 PM   #10
jwiles's Avatar
Its the same for the Kx.
camera, dslr, photography
K-x firmware upgrade - when? yusuf Pentax News and Rumors 18 07-10-2010 09:52 AM
Un-announced firmware upgrade for K-x? Deolman Pentax SLR Lens Discussion 1 05-27-2010 03:14 PM
k7 won't work after firmware upgrade obxeye Troubleshooting and Beginner Help 5 02-17-2010 02:47 AM
Firmware Upgrade gumpa Pentax DSLR Discussion 2 03-12-2009 01:18 PM
How to Upgrade Firmware? rzarbo Pentax DSLR Discussion 13 01-25-2008 04:19 PM
All times are GMT -7. The time now is 07:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
