07-24-2010, 08:07 PM   #1
Reportage's Avatar
is SDM speed faster on newer bodies?
am impressed with the light gathering capability of the 50-135mm f/2.8 at a recent photo show.
was the only dynamic subject available at the time. Used my most common settings plus a bit more usually reserved for fast primes for a demo. Its an indoor event so getting a picture that bright even at f/2.8 without flash using prime settings is quite amazing.
What i want to ask, is SDM speed faster on newer bodies like the K7 or same as K10D?
07-25-2010, 08:46 AM   #2
RonHendriks1966's Avatar
No idea. My guess would be NO. Pentax did not make a fast SDM (I have the DA*55mm and 50-135mm) but to my opnion it is very accurate. Sigma's HSM is much faster when I tried the 70-200mm on a K-7.
07-25-2010, 09:52 AM   #3
mysticcowboy's Avatar
Autofocus relies on hardware and firmware in the body, and is much faster all around for the K7. You should see a difference on almost all lenses, SDM or not.
07-25-2010, 11:55 AM   #4
QuoteOriginally posted by mysticcowboy Quote
I know. But Sigma's HSM is much faster then Pentax's SDM. Both tested on K-7.
07-26-2010, 03:24 AM   #5
Different body won't force SDM motor to rotate at higher speed.
07-26-2010, 03:48 AM   #6
AF speed is dependent on both the response time of the Autofocus system in the body, and the SDM motors driving the lens.
The SDM motors work at the same speed , but the K-7's AF response is faster than older bodies, especially in lower light. So the overall AF response is faster on the K-7, that's been my experience anyway.
07-26-2010, 05:36 AM   #7
anybody tried out using and SDM lens on a Kx?
im imnterested in snagging a DA* 16-50mm oooohhh the G.A.S
07-26-2010, 10:57 PM   #8
lurchlarson's Avatar
My 16-50 is faster on my brother's KX than on my K200d, but just a smidge.
camera, dslr, f/2.8, photography, sdm, settings
Faster AF-speed!? AndersPS Pentax DSLR Discussion 4 06-09-2010 08:12 AM
Old flashes and newer bodies Steve Beswick Pentax Film SLR Discussion 7 02-16-2010 03:21 AM
SDM and AF Speed? VHDEL Pentax DSLR Discussion 2 10-12-2009 06:18 AM
Would SDM lens speed up K10D's AF? drabina Pentax DSLR Discussion 27 01-02-2009 09:42 PM
Is Da 70mm f2.4 faster in AF speed comparing to Fa 77 Ltd? roentarre Pentax SLR Lens Discussion 17 02-10-2007 07:55 AM
All times are GMT -7. The time now is 08:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
