11-29-2006, 06:17 PM   #1
slip's Avatar
Can the K10 or K100 write to a USB 2 key?
I was wondering if anyone knew if either one of these cameras can write the shots to a USB 2 key instead of an SD memory card.
Since it has USB output (It does, doesn't it)if it could write to the USB key, wouldn't that be faster transfer rate?
thanks
randy
11-29-2006, 09:34 PM   #2
No, it can't. USB is a host/client connection, and both the camera and USB keys are clients.
11-29-2006, 09:45 PM   #3
slip's Avatar
QuoteOriginally posted by ccallana Quote
thank you
randy
11-29-2006, 10:05 PM   #4
BobS's Avatar
What you can do, is get a USB holder that takes SD cards, then pop the card into the reader. I bought one for less than $10 and use it to pass files between computers. My laptop has a built-in SD card slot, so transfer rates are really good. I just hope that the SD card cover on the K10D is up to being opened and closed A LOT.
11-29-2006, 10:40 PM   #5
rfortson's Avatar
Certain USB devices can act as a host. There are some MP3 players that will do this, specifically so you can use it as external storage for cameras and such. The marketing phrase seems to be USB OTG (On The Go), but USB host is what it's more correctly called.
camera, dslr, photography, usb
How MB/Sec does the K10 and K20 write at? rdrum76 Pentax DSLR Discussion 5 11-03-2008 10:59 AM
K100 vs K10 axl Pentax DSLR Discussion 11 10-20-2008 09:51 PM
K100 or K10 krs Pentax DSLR Discussion 8 01-06-2008 09:29 PM
ist. vs. K100 vs. K10 abieleck Pentax DSLR Discussion 7 07-19-2007 07:51 PM
K10 Impressions( Vs K100 Vs *ist D and DS) RiceHigh Pentax DSLR Discussion 4 01-17-2007 10:59 AM
All times are GMT -7. The time now is 05:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
