Originally posted by Clicker I say you should have gone with the Nikon, its essentially a D90 and the main features are better for your skate shooting, you won't need IS as much as you'll be panning most of your shots, IS is good when you have huge tele lenses. The 5000 gives you that tilt screen good for getting low or high angles, it also has better focusing for moving subjects these are just some of the advantages it has in this situation over the Kx.
Nikon D5000 Key Features
12.9 megapixel DX-format CMOS sensor (effective pixels: 12.3 million)
2.7" tilt and swivel LCD monitor (230,000 dots)
Movie capture at up to 1280 x 720 (720p) 24 fps with mono sound
Live View with contrast-detect AF, face detection and subject tracking
Image sensor cleaning (sensor shake)
11 AF points (with 3D tracking)
IS0 200-3200 range (100-6400 expanded)
4 frames per second continuous shooting (buffer: 7 RAW, 25 JPEG fine, 100 JPEG Normal)
Expeed image processing engine
Extensive in-camera retouching including raw development and straightening
Connector for optional GPS unit (fits on hot shoe)
New battery with increased capacity
72 thumbnail and calendar view in playback
Originally posted by clim920 Omg no don't do this to me now ARGH! More opinions?
12.9 megapixel DX-format CMOS sensor (effective pixels: 12.3 million) -
Kx has it
2.7" tilt and swivel LCD monitor (230,000 dots) -
Awesome feature, definitely wished it was on the Kx and the K7, I'd pay extra for it, a lot extra. Awesome feature
Movie capture at up to 1280 x 720 (720p) 24 fps with mono sound -
Kx has it
Live View with contrast-detect AF, face detection and subject tracking -
Kx has it
Image sensor cleaning (sensor shake) -
Kx has it
11 AF points (with 3D tracking) -
Kx has it
IS0 200-3200 range (100-6400 expanded) -
Kx has it
4 frames per second continuous shooting (buffer: 7 RAW, 25 JPEG fine, 100 JPEG Normal) -
Kx beats FPS by .7 frames per second, Nikon's buffer smokes the Kx though
Expeed image processing engine -
Kx has a Prime II engine, do the names matter?
Extensive in-camera retouching including raw development and straightening-
Kx has it
Connector for optional GPS unit (fits on hot shoe) -
Aftermarket universal GPS units
New battery with increased capacity-
Kx has AA's which are infinitely available, 1000 shots per charge easy
Not very relevant to the actual camera performance but cool anyway
Feature-wise they are both great cameras, beating out and losing to each other in different aspects.
Every argument for the Kx can be rebutted with an argument for the D5000, every argument for the D5000 can be rebutted with with an argument for the Kx. At a certain point you're just going to have to choose and start taking pictures.
The differences really wont be earth shattering since they are very very similar. I still prefer the Kx, but at the end of they both take pictures. There's endless pros and cons of each, with implications you haven't even begun to think about like lenses and third party accessories but you're probably going to get an ulcer going back and forth endlessly.
The easiest thing, go with the one you
like. Seriously, screw logic, if you buy something you
like you will be way happier and not have to grow to like it. Recently I had 500 to spend on a lens, I
liked the DA 15 but logic told me to get a Sigma 10-20mm, well turns out I still preferred the DA 15 after playing around with the Sigma for a little while, and I needed something I
liked if I was going to drop that much on it.
You'll feel better if you get what you crave, even if it defies logic to some extent, that's also how I picked my Kx. I wanted a white DSLR! and I got it and was thrilled with it. Even if I got a rebel or a Nikon and had access to cheap Nikon/Canon optics I probably would have always wished in the back of my mind that I got the Kx because it was white, it was sweet! and I
liked it.
Just remember the one truly unique and superior feature of the Kx is the outstanding low light performance, it's really set apart by it.
