08-06-2010, 01:19 PM   #1
Lowering image size to lower ISO noise?
I'm curious about something. Since high ISO noise increases as the pixel density gets higher, do you think that lowering the image size on the K7 from 14mp to 10 will help lower the noise?
Everyone I know that has/had a K200 talked about the smooth noise patterns because of its 10mp sensor. Also, the K100 did very well because it was 6. But does a 14mp sensor literally act like 10 when you lower it or does it just emulate it? Does the pixel density actually change?
I know I'm either going to do larger print shots or low light shots, never both. So I see no loss for me by dropping to 10MP at those occasions, especially when there'll be no IQ loss from the change.
I hope this made sense.
08-06-2010, 01:22 PM   #2
future_retro's Avatar
I'm honestly just guessing because I don't know for sure, but I think that no matter what JPEG settings you use, it captures a full 14mp RAW image and then depending on your JPEG settings, dumps a certain amount of information from that 14 MP RAW and then saves it as a JPEG accordingly. I don't think the JPEG settings are capture settings, but saving settings
08-06-2010, 01:40 PM   #3
Jasvox's Avatar
I theorized about this (as have many) in the past and according to my readings and findings, the short answer is NO.
Here's a good read and explanation, but there are many other examples if you search and read.
Downsampling to reduce noise, but by how much?: dpreview.com Editorial blog: Digital Photography Review
Jason
08-06-2010, 03:40 PM   #4
jimH's Avatar
I don't know about this, I've got a 10 mp k10 and on under exposed shots the noise is very bad.
08-06-2010, 03:57 PM   #5
JohnBee's Avatar
QuoteOriginally posted by jboyde Quote
It's a common thought I think
Because its come-up a umber of times over the ages.
Unfortunately, it doesn't quite work out this way and the results are less than beneficial.
The good news is that you can post process a file(full size) and reduce your final results a bit to help tighten things up(sharpness and artifacts).
However... since you mentioned high ISO and large format, my advice would be to take advantage of the K-7's faster FPS to achieve super resolution. Okay, super resolution is not actually a term(per say), but more of a technical term used by a company called PhotoAcute.
But the good news is that the software and your camera can achieve both cleaner ISO and higher resolutions simultaneously. As seen bellow:
ISO noise reduction:
Resolution enhancement:
Take Better Photos, reduce noise, increase quality and resolution of digital photographs. Leading superresolution technology.
PS. I've used this to create 3 -2.5x6' wall images for our living room.
08-06-2010, 05:50 PM   #6
jpzk's Avatar
QuoteOriginally posted by JohnBee Quote
PS. I've used this to create 3 - 4x6' wall images for our living room.
John,
This seems a bit awkward: how can any algorithm calculate and align pictures taken in continuous mode unless you've shot several bracketed pics; unless it's me not understanding the process, I can see a software doing this but with bracketed shots while the cam is on tripod so that everyting will be almost perfectly "aligned" to start with.
So, if I was to take several shots of an oncoming bird, for instance, I can hardly understand how the software would extract info from several pics taken that way and "make one good pic" !?
Sorry about barging in on your thread Jboyde, but as usual I am not quite understanding this process here esplained by John.
JP
08-06-2010, 06:08 PM   #7
JohnBee's Avatar
QuoteOriginally posted by jpzk Quote
You have indeed exposed one of the limitations of this technology. Which works well enough handheld, however... it has its limits too, and your example is one of those instances.
Having said that, for what its worth, the software does work quite well within the confined of its limits. I have taken a number of shots(handheld) which turned out okay enough with regards to moving tree's, waves etc etc.
TBH. I never really pushed the software to see how far it could deal with movement, but I have no doubts that it has its fair share of issues in this sens also.
Having said that, I think the software works best with scenery's and tripod shooting. Which turns out to be pretty impressive considering it almost doubles the effective resolution in the process.
08-06-2010, 10:30 PM   #8
mysticcowboy's Avatar
I have to say that I've been impressed with the results I've gotten with PhotoAcute, handholding for still subjects. No, it won't work if the subject is moving quickly. It will align multiple frames much better than Photoshop. As a matter of fact, PhotoAcute uses the slight differences in positon in its sharpening algorithms.
Unfortunately, most of my high ISO photos are handheld and of people, who have a bad habit of moving. ;-) If I can use a tripod, I often don't need the ISO bump.
To the original question. If you shoot full size then reduce the image size in post, much of the high ISO noise will be processed out in the reduction with any software. PhotoAcute isn't needed for that.
08-07-2010, 07:42 AM   #9
Going from 14MP to 10MP does not produce sufficient compression to make much difference in visible noise.
Going down to 1 MP - still good enough to view full screen - does do the trick. The averaging of values from adjacent pixels involved in shrinking the photo helps remove a lot of high-frequency noise, but any large blotches of noise will still be visible.
Even shots from P&S cameras with mediocre High-ISO performance can look presentable when you shrink it down several X.
08-07-2010, 08:30 AM   #10
RioRico's Avatar
QuoteOriginally posted by kittykat46 Quote
Almost everything looks good if it's small enough. And printed on textured paper. And mounted in a large matte and frame. And hung in a dark corner. In a closet.
08-10-2010, 08:19 PM   #11
Marc Sabatella's Avatar
It's something of a myth that noise correlates well with pixel density. It actually correlates much better with *sensor size* and is largely independent of pixel density. People often get the mistaken impression that more pixels means more noise because they make the mistake of viewing the higher resolution image larger, thus magnifying the noise.
No, it's 14MP.
08-10-2010, 09:30 PM   #12
er1kksen's Avatar
Marc, you're certainly correct about the pixel density misconception but the K200D is definitely 10mp. Maybe you thought he meant K20D?
to jboyde: The K7 has superior noise characteristics, regarding the affect noise has on the output rather than pointless 100% views, to the earlier 10mp and 6mp sensors, particularly in print. No image-size adjustments are going to change that. Dedicated NR programs can help reduce the appearance of the noise that does occur, however. Give the NeatImage free trial a try. Lightroom 3 and Topaz Denoise are generally considered the current leaders in noise reduction, though they will cost money.
08-11-2010, 06:43 AM   #13
Smaller pixels are not necessarily "noiser" than larger pixels. They simply have a smaller bucket (pixel) to catch photons in. For bright lighting conditions, a P&S camera will take nearly the same picture as a larger sensor camera (aside from optics of course), because the number of photons captured in each bucket is much larger than the noise captured in each bucket.
ISO level is just the amplifier setting, before the A/D converter that converts each pixel data from an analog voltage to digital bits. On a K-x, an amplifier setting of 1x (ie no amplification), is the equivalent to ISO 200, and an amplifier setting of 2x is ISO 400. As the amplification is increased, the noise increases proportionally to the image data.
With virtually all camera sensors, reducing the resolution is accomplished by simply subsampling the image pixels - ie throw away some of the pixels to make a smalller image file. Some of the point and shoot cameras have a "digital zoom", where they throw pixels away from the edges to effectively "zoom in". But most SLR's just subsample the pixels across the frame to produce smaller image files. In any case, the amplifier setting is independent of the subsampling, and noise is not affected by using smaller image settings.
With some imaging sensors, specifically the huge CCD arrays they use in telescope facilities, the CCD clocking can be arranged to combine adjacent pixels into larger super pixels. This is called binning. The larger super pixels have a higher dynamic range (ie a bigger bucket to catch photons in), but obviously, have a lower resolution for the whole array.
It would be really neat if camera sensors could do binning, because then as you reduce the image size, you increase the dynamic range of each pixel. But, the camera electronics would have to be significantly different to take advantage of this.
08-11-2010, 07:37 AM   #14
er1kksen's Avatar
QuoteOriginally posted by leadfoot Quote
Well, some of them can... a bit pricier than your average Pentax, though.
08-11-2010, 02:44 PM   #15
QuoteOriginally posted by er1kksen Quote
Oops, you're right, I read the final "0" in "K200" as a "D". But for the record, there is no "K200" - there is a K20D, a K200D, and a K2000, but no K200.
camera, change, dslr, image size, iso, loss, noise, photography, sensor, shots, size
Image Size vs Document Size vs Resolution vs Resampling vs ... AHHHH! veezchick Digital Processing, Software, and Printing 13 08-02-2010 03:57 PM
Why is ISO lower with the bulb (k-x)? justtakingpics Pentax DSLR Discussion 1 04-22-2010 12:25 PM
GX10 Lower iso1600 noise jamesm007 Pentax DSLR Discussion 1 12-27-2008 12:26 PM
There are some information that K10D with revision 2.1 and higher has lower noise ogl Pentax DSLR Discussion 86 04-25-2008 04:24 PM
Maximum Printed Image Size vs ISO - Successful or Not? Sideways Digital Processing, Software, and Printing 6 08-08-2007 11:00 AM
All times are GMT -7. The time now is 06:21 PM. | See also: NikonForums.com, part of our network of photo forums!
