08-06-2010, 02:02 PM   #1
What difference does JPEG star quality make?
What is the difference between 4 star (****), 3 star (***), 2 star (**), and 1 star (*) JPEGS on the K7?
I can't seem to make it out.
08-06-2010, 02:05 PM   #2
The more stars, the less compression is applied to the raw data to get the JPEG file.
This is "lossy" compression, meaning information is lost in the process of compressing and expanding the image file. Fewer stars mean that less info about the image is preserved.
I just set it to the best quality (most stars) and forget about it. Cards are not that expensive that I have to lose data to save space.
08-06-2010, 04:37 PM   #3
bkpix's Avatar
Best way to answer your own question is give it a try. You might be surprised at how good the quality of more-compressed files is, especially if you use them to make prints.
Adding compression gives you the option of cramming more photos onto a card if you find yourself, for any reason, stuck for space.
08-06-2010, 04:52 PM   #4
SpecialK's Avatar
Ah, but Pentax has better than "best" now (premium), so the best is not the best always :-)
08-06-2010, 07:33 PM   #5
I did a test months ago on the K-7, comparing between 4 stars and 1 star, on a tripod.
With an average lens and higher ISOs i.e. downgraded resolution anyway, I hardly see any difference.
Even with a DA Limited, at ISO 100, the differences are subtle, not something you can easily point to. Just a little bit less fine detail, a little bit less "pop" with the colour and contrast.
If for some reason you really need to conserve SD card space e.g. forgot to bring a spare card along, you don't lose much IQ by switching to fewer "Stars" on jpeg.
08-06-2010, 11:55 PM   #6
RioRico's Avatar
I'm waiting for the firmware mod that lets you turn it up to ***** five stars.
08-07-2010, 06:56 AM   #7
I want the "Spinal Tap" version. You know, the one that goes to eleven.
camera, dslr, photography, star
Photo quality difference between DA Star 55mm F1.4 vs FA 31mm F1. 8 Limited tin008 Pentax SLR Lens Discussion 12 07-04-2010 02:36 PM
K-x vs K-m JPEG quality deadwolfbones Pentax DSLR Discussion 8 11-21-2009 08:47 PM
RAW + JPEG with JPEG on One Star quality laissezfaire Pentax DSLR Discussion 58 12-10-2008 02:42 PM
JPEG gallery quality Duncan J Murray Site Suggestions and Help 1 04-27-2008 02:38 PM
K10d JPEG quality rwa Pentax DSLR Discussion 35 11-29-2007 09:34 AM
All times are GMT -7. The time now is 12:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
