Originally posted by RBellavance The comparison and mention of "35mm equivalents" is from the users. The companies *are* making lenses specifically for that format (Pentax's DA, Nikon's DX, Canon's EF-S, etc), and they *are* giving you the correct focal length for the lenses. A 50mm lens is 50mm whether it is mounted on an APS-C camera (where it is a short tele), and 135 film camera (where it is a "normal"), or a 6x4.5 MF body (where it is a wide-angle). The following Wikipedia article explains the "crop factor" quite well:
Crop factor - Wikipedia, the free encyclopedia Another good one is on Luminous Lanscape:
DSLR Magnification
The "problem" (need to compare) probably comes from the fact that it is possible to use the same lenses on APS-C and 24x36mm bodies.
You are correct. Maybe I chose incorrect wording to explain my point of view. The term "standard lens" for example, is a lens that gives a normal looking perspective which is close to what the human eye sees. This occurs when the length of the frame diagonal
(Hypotenuse - the square of the length of the hypotenuse equals the sum of the squares of the lengths of the two other sides.)is approximately the same as the focal length. The diagonal of a 6x7 format, for example, is about 100mm which makes a 100mm lens a standard lens in the 6x7 format. The K100D uses an APS-C format size of approximately 23.5mm x 15.7mm. A normal lens for this format is therefore approximately 33mm, or 50mm in 35mm camera format, or 73mm in 645 medium format or 90mm for a 6x7 medium format camera. If you apply this backward, a 90mm lens in the 6x7 format makes a 245mm lens in the APS-C, a factor or approximately 2.7x. The correction factors are approximate as follows: 1.5x for 35mm format lenses, 2.2x for 645 medium format lenses and 2.7x for the 6x7 medium format lenses. A 200mm lens in the 6x7 format gives an effective focal length of 540mm when installed on the K100D. The correction factors may not be 100% accurate as the numbers were rounded off, but you get the idea. You can forget about getting wide angle results with any medium format wide angle lens.
In short, manufacturers should make normal lens and label them as such for the APS-C which would be a approximately 30mm. One company, Sigma, did just that with their new 30mm f/1.4. It's crazy to always have to figure out what the equivalent of a 50mm lens manufactured for 35 mm cameras will be on your APS-C camera.
When I lived in Canada, the systems were changed from English to Metric. For a while, everybody was confused because we were thinking in English measurements in our heads and translated those figures into metric. After a while, the mind was thinking metric and everyone ceased to translate in their minds. A normal lens for the APS-C format is 30mm. Above that its telephoto, 60mm is 2x, 90mm is 3x and so on. It really boils down that each format (maybe more in the future) should clearly explain to the public at large what is a normal lens for that format, as bench mark.
I'm probably as clear as mud.
Pentax dslrs
