08-11-2010, 06:40 PM   #1
NiZn Batteries: A warning
I bought a set of powergenix nizn batteries off amazon a while back, tried using them on a trip. Out of the box, they worked great in my k100d. However, after a recharge, the voltage was apparently too much for some part of my system. After a couple shots, the shutter just kept going.
Just a non-destructive transistor lock up most likely, but if anything acts funny after you start using nizn batteries, I'd discontinue using them in said device.
All that said, they seem awesome in flashes so far. (Don't use them in pentax brand flashes!)
08-11-2010, 06:47 PM   #2
Why not use them in Pentax brand flashes vs. other flashes?
Paul
08-11-2010, 07:31 PM   #3
frank's Avatar
I got a set of NiZn batteries too, rated at 2500mA and 1.6v. Seller said it's good for flash. Tried them in my Metz flash, worked okay. But I have some problem recharging them w/ my LaCrosse charger. Somehow the charger always shows those batteries are full, even after a couple hundred flashing
BTW, mine are these:
http://www.engadget.com/2009/11/09/powergenix-nizn-rechargeable-aa-batteries...-some-cells-w/
Thought it over, it's probably a bad idea to charge these NiZn batteries w/ a NiMh battery charger ....
08-11-2010, 09:10 PM   #4
QuoteOriginally posted by frank Quote
PowerGenix NiZn rechargeable AA batteries: finally, some cells worth buying -- Engadget
Even says in the article you posted: the special charger (needed for charging NiZn batteries)
08-11-2010, 10:53 PM   #5
Paul, when these batteries first came out, there was news on the forum about them causing one of the Pentax flashes, I believe the 360, to go poof. Apparently Pentax skimped on the overvoltage protection, and these flashes can't handle batteries with too much juice. This is quite concerning, seeing as I've occasionally seen alkalines with voltages nearly as high. I made the comment about Pentax flashes in general as a CYA; I don't want to feel responsible for anyone's dead flash.
Frank, NiZn batteries, fully discharged, are at 1.6 volts or so, and fully charged, they're at 1.9; a traditional charger only goes up to 1.2 volts, rendering your LaCross useless for charging NiZn batteries. Also, NiZn's are supposed to be topped up, like lead acids, if I remember correctly. Draining them isn't recommended.
08-12-2010, 06:39 AM   #6
NiZn's need their own charger. you can not use NiMh chargers with these batteries.
After a recharge, the voltage is usually 1.7 - 1.8 v but decreases quickly when used to 1.6 and stays there
Some devices can't tolerate the higher voltage (note: the nominal voltage is 1.6 just like NiMh's that fresh out of the charger are usually at 1.4v but drops to 1.2v nominal)
Some flash units have been reported to burn out w/ these batteries.
I've used them on my K2000 w/o issue, however, YMMV
08-12-2010, 04:58 PM   #7
I have not heard of this type before. The voltage range does seem like it would cause problems in devices that are designed for 1.2 to 1.5 volts. Are they supposed to be better than the NiMH's?
08-12-2010, 06:39 PM   #8
frank's Avatar
QuoteOriginally posted by Silverkarn Quote
I got the batteries before I saw the article It's not that I really want the batteries, it's someone passed to me and asked me test them out. But he didn't give me a charger for it
QuoteOriginally posted by m88k Quote
Yeah, that's what I figured too. I'm not buying a special charger for them. Got enough eneloop batteries already. Probably just keep them as souvenir
08-12-2010, 07:29 PM   #9
How about GP "Gold Peak"? GP is very good. I think now 2700mah or 3200mah.
08-12-2010, 08:49 PM   #10
wll
I use NiZn for my K-x-and they work great, if the new K-r works with Lithium and rechargeables I will sell the K-x and get the new model, as long as the new model has the same sensor or an upgrade to the K-x ......... no K-7 crappy high ISO stuff.
wll
08-13-2010, 12:12 PM   #11
Marc Sabatella's Avatar
QuoteOriginally posted by Bob photo 4 life Quote
Well, they are higher voltage. That could be better for some devices, and in particular, with a Pentax DSLR, would potentially speed AF by running the motor faster. Plus they'd likely keep their voltage above the necessary threshold for more shots because they are starting higher. But not all devices can handle the higher voltage. Do a search - there have been several threads on this topic before. This is the first I've heard of anyone reporting any negative effect form using these in a Pentax DSLR.
08-13-2010, 03:08 PM   #12
OK, thanks. I install mobile electronics for a living and most of those have a range of about 11 to 15 volts operating range. If a voltage regulator goes out and the alternator goes over that, the component shuts down to protect itself.
I didn't know if that would be the case with photo gear.
08-13-2010, 03:50 PM   #13
There is a voltage regulator circuit in-between batteries and electronics to provide constant voltage. Depending on the type of regulator, too much voltage can cause overheating of the regulator circuit, leading to component failure if there is no thermal shutdown circuit. Switching regulators do not have the overheating problem. Some switching regulators can even increase the battery voltage when batteries run low, to provide the voltage required by electronics. These typically include shutoff circuitry because as the battery voltage dips lower, the additional current requirements to achieve the voltage required by electronics can cause overheating. Of course all this additional circuitry costs more.
"potentially speed AF by running the motor faster." is bogus information imho. <<< WRONG! see next post.
08-13-2010, 04:28 PM   #14
no, not bogus
the AF DOES run faster with NiZn's, that's a known fact from many folks who have tried this type of battery.
definitely, NOT bogus
whether of not it causes harm to the camera is another issue.
08-13-2010, 04:48 PM   #15
QuoteOriginally posted by opiedog Quote
Thanks. Post has been edited.
batteries, camera, dslr, nizn, photography
Are NiZn batteries safe for Pentax K-x? BobRad Pentax DSLR Discussion 22 07-14-2010 08:53 AM
NiZn batteries possibly not good for K-7 Lance B Pentax DSLR Discussion 1 04-09-2010 10:07 AM
NiZn battery warning for AF360FGZ flash dietcokefiend Flashes, Lighting, and Studio 24 02-13-2010 08:08 AM
540FGZ Flash Recycle Times for NiZn Batteries JackBak Flashes, Lighting, and Studio 6 02-04-2010 11:06 AM
Wanted - Acquired: NiZN AA's+Charger shipping from Amazon.com to EU ytterbium Sold Items 2 11-22-2009 05:04 PM
All times are GMT -7. The time now is 04:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
