08-11-2010, 10:48 PM   #1
Pentax K7 Battery Short?
Hi, I purchased my first DSLR a Pentax K7 last month and have noticed a bizarre issue i fear i will need return for warranty.
The battery discharges itself over a few days.. If i leave the battery in the Camera for a day or two, when i return the battery will be dead flat. I have since gotten a 3rd party battery grip and spent time testing with two batteries and swapping the orignal battery with a 3rd party and i have the same result.
The batteries in the battery grip will seemingly keep their charge, but anytime a battery is in the body it will be dead-flat. I use the term dead flat because they seem to be cold temperature and the Pentax charger will even flash the green light to show 0% charge. (usually the light stays green)....
Anyone care to throw some suggestions at me? Has anyone here heard of such a problem with Pentax K-? Cameras. I really don't want to send it back just for this battery issue, as it's otherwise perfect. Ideas welcome!
08-11-2010, 10:58 PM   #2
Wheatfield's Avatar
Send it back.
That isn't normal, and since you've tested it with 2 batteries, it would pretty much have to be the body at fault.
Send back the OEM battery with the cameras so they can reference it to standard as well.
08-12-2010, 12:57 AM   #3
hcc
hcc's Avatar
+1
This is not normal. Send the camera for warranty repair.
08-12-2010, 03:00 AM   #4
Thanks, I will send it back then. I have been slowly adding a few lenses haven't had much chance to play, Now i have to go without it, Grrrrr!
08-12-2010, 06:30 AM   #5
Wheatfield's Avatar
If it's only a monthly old, go for an OTC replacement rather than a repair. Depending on who your vendor was, there is a good chance they'll do it for you after such a short ownership period.
I know my local vendor will pretty much OTC replace any camera that goes flaky within the first few months
08-12-2010, 07:19 AM   #6
I leave the batteries in mine for so long that I actually forget when the last time I charged them was. That's with All my cameras. Definitely not normal for them to drain in a couple days of just sitting. The only situation I can think of where You would be causing that is if you have the camera set to never turn off with inactivity (I do) and forget to turn it off (I have).
11-13-2010, 01:33 PM   #7
i have the same problem with battery
hou you resolved the problem?
11-13-2010, 02:45 PM   #8
QuoteOriginally posted by koper Quote
I have not as yet, I've been too busy using the K-7 to send it back for repair as yet.
I've been using a 3rd party battery grip, the grip does not exhibit the problem, So i have kept the grip on for 3months and it's worked fine.
Perhaps if i upgrade to a K-5, I can finally send it for repair.
11-13-2010, 07:04 PM   #9
Hypocorism's Avatar
QuoteOriginally posted by Freak Quote
Or, run out of warranty space first, maybe?
You're a procrastinator. Get it fixed or replaced asap.
That was pretty expensive for an odd lemon.
.R.
11-13-2010, 08:17 PM   #10
QuoteOriginally posted by Hypocorism Quote
.R.
I still have about 7-8months warranty on my K-7 so not too worried, Not really procrastinating, I simply have no need to send it for repairs until i can afford to be without it. Besides it would give me a good excuse to upgrade to a K-5.
But yes I would recommend to 'koper' send it for repairs, back to Pentax.
(It may be interesting to compare serial numbers!)
11-13-2010, 09:35 PM   #11
Hypocorism's Avatar
ROFL! That takes the cake for being the most weird improvised reason to justify buying a K-5 that I've read yet. Just go and order one anyway Scott, a new K-5 would make a nice pre-chrissy present for self.
.R.
11-13-2010, 09:35 PM   #12
i personaly think that the problem is that i work in wrong camera mode
currently i charge the battery before shooting and have extra battery arround me
11-14-2010, 05:16 AM   #13
QuoteOriginally posted by JeffJS Quote
Same here. I've had batteries at half charge sit in the camera for a week and still work. (I have 3 batteries. They are numbered 1 - 3. I only charge them as I run them down and keep them in rotating use.)
12-04-2010, 09:54 PM   #14
i think that there is a need to reset all camera functions to original state-it resolves the problem
i have done this and till now the problem with batteries did not repeated
batteries, battery, camera, charge, dslr, grip, issue, k7, light, pentax, photography
A Brief Introduction. (Short shot on a Pentax K-x) johnnybodybags Video and Pentax HDSLRs 3 11-02-2010 06:13 PM
For Sale - Sold: Pentax D-BG2 Battery Grip in Like New condition + Generic Battery jjdgti Sold Items 2 07-15-2010 06:06 PM
For Sale - Sold: Pentax 10-17mm Fisheye, AF 360 Flash, D-BG2 Battery Grip, D-L150 Battery, Remo dazman Sold Items 19 03-31-2010 03:48 AM
For Sale - Sold: Brand New Pentax BG2 Battery Grip for K10D and K20D + aftermarket battery jjdgti Sold Items 3 05-07-2009 10:43 AM
For Sale - Sold: Pentax Battery Charger D-BC50 + NP400 L-ION Battery happicamper Sold Items 1 10-05-2008 05:25 PM
All times are GMT -7. The time now is 11:19 PM. | See also: NikonForums.com, part of our network of photo forums!
