08-14-2010, 05:22 PM   #1
ismaelg's Avatar
K100D Super: Class 6 or 4 SD?
Hi,
The K100D Super is not a speed demon. I know. Would a class 6 or higher card make a difference vs a Class 4?
Thanks,
EDIT:Trying to edit the title. It is K100D not K1000D
08-14-2010, 06:48 PM   #2
For the price difference, I would go with the class 6 regardless. I would think the only real difference there would be is in write speed and that may affect your fps rate but that's about it. If you don't use continuous drive (as I don't), I doubt it matters much.
08-14-2010, 07:20 PM   #3
GerryL's Avatar
I have read that batteries matter though, that instead of using 1.2V rechargeables and using 1.5V makes it a bit faster...meaning since you are using four 1.2V batteries, you are actually losing/sacrificing 1.2V that is lost since optimal battery voltage with four 1.5V is 6volts.
..that is why they say that the CRV3 batteries cranks the optimal performance out of the K100D super or any "AA" operated DSLRs.
08-14-2010, 07:20 PM   #4
alohadave's Avatar
It doesn't matter with the K100D Super. The shot buffer can only hold three RAW files.
You will never, ever stress an SD card enough with this camera for the class to affect anything.
08-14-2010, 08:16 PM   #5
ducdao's Avatar
QuoteOriginally posted by alohadave Quote
+1. I tried both Class 2 and Class 6 on my K100D and see no difference so I used Class 2 on on K100D and Class 6 on my K10D instead.
08-15-2010, 05:29 PM   #6
I can attest to the 3 shot buffer, but I don't know how fast the camera to card interface is. If anything, the smaller the buffer, the more important it is to get data to the card as fast as possible.
On the other hand, probably the actual card specs matter more than the claimed class, so you'd have to know the actual specs for the models of cards you're interested in, and then compare it to what speed the k100 is capable of.
Paul
08-17-2010, 11:20 PM   #7
theperception2008's Avatar
Location: Łódź, Poland and Riverside, California, U.S.A
QuoteOriginally posted by tibbitts Quote
Paul
I got the chance recently to work with an Adata class 6 card and have had an Extreme III 20mb/ w/r
version and I have to say that under casual shooting, it's hard to notice. However, if you are filling up the buffer continuously, then you will see the difference. I was actually getting 4 shots before the camera would pause a short 1-2 secs to finish writing with the Extreme III, The Adata took 3 shots and took about 2-3 seconds to write on the card. There is a difference, but with the K100D it's small. It does play a key part in exporting the files to your comp though, there is a clear difference there! Much faster with the Extreme III!
camera, class, dslr, k100d, photography
What problems can I expect using an M-class lens or older on a K100d? Grimlock Pentax SLR Lens Discussion 10 09-10-2007 09:31 PM
All times are GMT -7. The time now is 07:59 PM. | See also: NikonForums.com, part of our network of photo forums!
