08-19-2010, 10:54 AM   #1
K-x Freezing :(
Purchased my K-X late January. I LOVE it. It's been taken care of well, updated firmware, ect.
Recently though, this has become a love-hate relationship.
My k-x will lock up when shooting ( i use a Pentax-M f1.7 50mm mostly)
Heres a description of the lockup: The LCD screen will freeze, all buttons on the camera become useless, and when i turn the power to off the camera still stays on ! It gets worse- after that the only way to turn it off is to remove the batteries. It usually doesn't even turn on after i put them back in and try too. The shutter will randomly release at this point. Movie mode seems to do this more often, but it's happened while shooting in M mode too.
Heres what i've tried: New batteries, Brand New SD card, Cursing (j/k)
I went to the place where i purchased it and they offered to send it back to Pentax for repairs, but i thought i'd try one last hail mary here and see if anyone can offer some insight or advice as do what the problem may or may not be, and possibly a solution that doesn't involve returning it.
I know, TL; DR.
Cliffs: Cam locks up when shooting in movie mode mostly ; Doesn't Power off properly. It has done it with both kit and M lens.
08-19-2010, 12:29 PM   #2
Hi,
I had the same problem once with my k-x. I was in movie mode....and yes I had the most up to date firmware.
I haven't experienced the issue since so i don't know what the problem was.
08-19-2010, 12:36 PM   #3
what type of batteries are you using? fresh lithiiums or new NiMh's?
movie mode slurps battery power very quickly and if there happens to be something intermittent w/ your battery or contacts, that could cause it to lock up.
just my 2 cents
08-19-2010, 02:09 PM   #4
hcc
hcc's Avatar
I agree with opiedog. The movie mode uses a lot of power. You definitely need to have full-charged, good quality batteries, as well as the latest firmware that improves the battery issue with the K-x. Also you may need to reset the K-x settings after each incident.
However, if your problems occur with new batteries, with the new firmware, I would consider sending the K-x for repair.
batteries, camera, dslr, k-x, mode, movie, photography, power
Hi from freezing Houston samper Welcomes and Introductions 3 02-01-2010 11:09 AM
fifty at minus 10 below freezing Douglas_of_Sweden Post Your Photos! 8 01-08-2009 07:07 PM
Brrrr... it's freezing!!! hamidlmt Post Your Photos! 15 11-06-2008 08:31 AM
Freezing my... at the Arboretum codiac2600 Post Your Photos! 7 11-16-2007 12:21 PM
K100D Freezing up? FotoPete Pentax DSLR Discussion 4 09-22-2007 11:26 PM
All times are GMT -7. The time now is 08:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
