Originally posted by Marc Sabatella I just didn't want anyone to get their hopes up thinking there was an actual Li-Ion AA, or that someone figured out a way to make regular Lithium cells rechargeable. The advantage of either of those over the current crop of hybrid NiMH cells would be higher voltage and lighter weight for the same charge.
Actually, I think someone *is* marketing a Li-Ion AA now, but it's voltage is way too high to put in a camera expecting ordinary AA's.
AA sized Li-Ion 3.7 rechargeable batteries are actually fairly common - they are called
14500 -
there are lots of sources for the 14500, so they are not that obscure
- the reason why they are not better known is due to exactly the reason that their nominal voltage is 3.6/3.7V and can deliver very high currents -
so probably would
FRY most devices that use regular AA batteries (nominal 1.5V)
Do a
search on 14500 Li-Ion battery
and there are plenty of vendors and forums threads on the 14500 battery.
One might want to note that the rumors of the new Pentax
K-r will use BOTH a lithium battery and standard AAs (brilliant!) " -
(But any Pentax dSLR using AA batteries is already capable of using regular AA and
1.5V lithium AA..... )
however that rumor may mean "
K-r (both LiIon and AA) " (link to 1001noisycameras.com)
