08-21-2010, 11:43 AM   #1
patriotap's Avatar
Anyone know if the k20d....
supports SDv3?
08-21-2010, 11:49 AM   #2
Ole
Ole's Avatar
The K20D suppors SDHC and the original SD cards.
08-21-2010, 11:52 AM   #3
patriotap's Avatar
Thanks, but is it SDv2 or v3? Reason I ask is that SDvX.X is the firmware version in the K20d that works the SDHC cards. If its v2 it only allows the slower SDHC cards, v3 the faster ones.
SO, I dont want to waste $$ a Class 10 SDHC card if the k20d is at v2, since it will only work at a class 4 or 6 speed. Its like the USB 1.0 vs USB 2.0 in the computer world
08-21-2010, 12:02 PM   #4
JohnBee's Avatar
QuoteOriginally posted by patriotap Quote
supports SDv3?
As far as I know, only SDXC cards are based on the new SD 3.0 standard. Though I think as SDHC will fill continue the gap as it mature for some time to come.
And then there is always the possibility of a firmware update too. Though I doubt it would invoke a performance upgrade, I suspect they will be able to maintain compatibility the the new format as was seen with SD/SDHC.
08-21-2010, 12:06 PM   #5
patriotap's Avatar
32GB Class 10 SDHC Team High Speed Memory Card 20MB/Sec
What Im looking at getting if the k20d can support v3
08-21-2010, 12:22 PM   #6
AFAIK, even if it did support V3, its hardware doesn't write that fast...
I'd buy it if it's not much more though...the next body probably will support V3....
08-21-2010, 12:42 PM   #7
patriotap's Avatar
Thanks kenyee, thats even worse, its about a $25 difference over the class 4/6 ones.
08-21-2010, 02:14 PM   #8
imtheguy's Avatar
I use some Transcend Class 10 16GB cards and all is fine in the k20d firmware v 1.04. My other cards are all Sandisk Extreme III 20/30MB and I can't tell any difference but have not tried to stopwatch a buffer full. Does it work? Yes.
08-22-2010, 12:41 AM   #9
patriotap's Avatar
Thanks Lee, yes they will work, just wont get the speed. The class 10 wont go any faster than the class 4 if its not SDv3. Or as kenyee said, the hardware doesnt support the transfer rate of the class 10.
08-22-2010, 01:22 AM   #10
Mike Cash's Avatar
You couldn't have put the other two words in the thread title?
camera, dslr, photography
In Canada: Summer Rebates for K20d or K20d plus lens Pentaxtic Pentax DSLR Discussion 1 07-17-2009 11:34 AM
Magic Lantern Guides: Pentax K20D and MasterWorks: Jumpstart Guide for the K20D. Reportage Troubleshooting and Beginner Help 10 02-12-2009 10:24 PM
All times are GMT -7. The time now is 03:26 PM. | See also: NikonForums.com, part of our network of photo forums!
