08-22-2010, 03:19 AM   #1
Faulty Shake Reduction Switch
Hi, the shake reduction in my K10D stopped working recently, and this was put down to a faulty surface-mounted switch on the A200 circuit block. I was told that the only way to fix this, was to purchase a new A200 PCB costing about 20, but I was wondering if anyone knows if the switch can be bought as a separate component? It's a tiny push-to-make (I assume!) switch measuring about 4mm * 4mm * 1.5mm-picture attached. In addition to the soldered contacts, it has a couple of small plastic locating lugs which protrude through the flexible PCB. Name:  SR Switch 3.jpg
08-22-2010, 04:22 AM   #2
amoringello's Avatar
Probably not from Pentax.
If you have a local repair shop, they might be abel to order one.
Sadly Pentax is pretty small and these types of repairs get shipped to one of a few repair centers.
If anything, you can try somewhere like C.R.I.S cameras (criscam.com) and see if they'll send you the part.
Either way, most likely they would only have the PCB anyway and not even be able to sell a single component. Most places would not waste time soldering such a small component when it is easily replaceable with a fairly low priced PCB.
Still, you can try.
08-22-2010, 04:30 AM   #3
Hi, actually it took less time to unsolder & remove the little switch than it would have done to remove the whole PCB (and less risk of damage)! I've had a quick look at various sites selling SM components, but no luck so far. I'm sure it's just a standard switch probably used in all sorts of cameras, i-pods etc, it's just knowing where to look. I'll probably end up getting the whole PCB in the end...
08-22-2010, 06:10 AM   #4
Try Digikey for the switch.
DigiKey Corp. | Electronic Components Distributor | United States Home Page
08-22-2010, 09:20 AM   #5
Check eBay for a cheap broken camera to use for parts if you cannot find the switch you are looking for.
08-31-2010, 08:04 AM   #6
Ok thanks to all for your help, here's what I did to fix this problem: I couldn't match the switch, so I bought the complete new PCB, but unsoldered the little switch from it & soldered it into my old PCB. I thought this was less risky than removing & replacing the entire flexible PCB. My camera's now working perfectly!
James.
4mm, a200, camera, dslr, pcb, photography, reduction, shake, shake reduction, switch
Do you always have shake reduction ON? gawan Photographic Technique 18 08-01-2010 02:36 PM
Shake reduction julianactive Pentax SLR Lens Discussion 2 05-06-2009 04:13 PM
Thank you Shake Reduction! tcdk Post Your Photos! 4 09-03-2008 09:29 AM
shake reduction jay legere Pentax DSLR Discussion 7 01-20-2008 07:45 AM
Any problems with broken K10D anti-shake switch? Katsura Pentax DSLR Discussion 11 07-11-2007 05:48 PM
All times are GMT -7. The time now is 01:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
