08-23-2010, 07:37 AM   #1
K20D overexposure
In the past few weeks that my K20D with Katz Eye focusing screen has begun overexposing by several stops. This happens both my DA 18-55mm f/3.5-5.6 AL, and my A-series manual-focus lenses, and my M-series manual-focus lenses. (I FWiW, I don't use the "green dot" to determine exposure with M-series lenses; I use the DoF-preview in Manual Exposure mode.) The overexposure seems to be consistent and I need to dial-in two or three stops of negative exposure-compensation or meter in manual-mode to compensate.
My K20D has firmware revision 1.03, and I tend to use the camera in spot-meter mode.
Here's a 2MP sample image (with intact metadata; 1MB) made with the camera in "P" mode with the DA 18-55mm f/3.5-5.6 AL:
http://mcfaddenphoto.com/temp/K20D_auto_exposure.JPG
Any ideas about what has happened? Is a trip back to Pentax in order?
08-23-2010, 08:07 AM   #2
The chances are the problem is you are having is using spot metering with the Katz Eye screen. The split screen focus in the center is a known problem. Refer to the Katz Eye web site and read their test results. I have one on my K20D also and spot metering is inconsistant to say the least. If you were having good results before, I would suspect you were lucky in the placement of the split screen and it has shifted a miniscule amount. Getting it back to where it was would be trial and error and unreliable.
08-23-2010, 09:15 AM   #3
paperbag846's Avatar
The above post is bang-on, the katz-eye site even admits to this.
See if center-weighted metering helps.
If anything, that should give you an underexposed image, as the k20d's meter is fairly conservative.
08-23-2010, 09:22 AM   #4
It now a trio...
Spot metering with the Katz Eye (or any other split image screen) is a no-no.
(Owns the Katz Eye, but seldom uses spot metering)
08-24-2010, 06:14 AM   #5
Thanks for the replies about spot-metering and the Katz Eye. I will certainly visit the Katz Eye website and read their test results and I will do some tests with the camera set to use center-weighted metering.
08-25-2010, 06:36 AM   #6
A set of quick snaps with the camera set to center-weighted metering were properly exposed. I tried both my auto-focus and manual-focus lenses.
I did find the caution on the Katz Eye website against using spot-meter mode. I think I must have seen that before I installed my Katz Eye but I must have forgotten it.
I think you guys have solved my problem--many, many thanks!
William
18-55mm, camera, da, dslr, exposure, k20d, lenses, m-series, manual-focus, mode, overexposure, photography
K-x overexposure? kevingt01 Pentax DSLR Discussion 5 05-17-2010 12:45 AM
consistant overexposure dougmc Pentax Compact Cameras 3 04-21-2010 12:46 AM
overexposure with Metz flash, K20D, and 50mm 1.4 Super Tak lisa.ireland Pentax SLR Lens Discussion 4 11-08-2009 12:50 PM
K20D overexposure in macro Substitute Pentax DSLR Discussion 17 10-27-2008 11:35 PM
overexposure with k200d? longerboats Pentax DSLR Discussion 7 10-15-2008 10:24 AM
All times are GMT -7. The time now is 01:46 PM. | See also: NikonForums.com, part of our network of photo forums!
