08-27-2007, 03:49 PM   #1
K10D at 2 Megapixels
Hello,
A quick question. If I set the K10D to take 2 Megapixels pictures (or 6), does it crop the picture or there's an averaging algorithm?
Thanks,
Etienne
08-27-2007, 04:24 PM   #2
It does not crop.
08-29-2007, 05:04 AM   #3
FotoPete's Avatar
QuoteOriginally posted by erollin Quote
Hello,
Thanks,
Etienne
Haha that would be awesome. but its the same as going into photoshop and cropping out the center 2mp.
08-29-2007, 08:24 AM   #4
well, as long as we have a concensus.
08-29-2007, 09:29 AM   #5
JPEG size...
When a digital camera "takes" an image it always captures the maximum amount of data. To create a JPEG image the internal software down samples the data to create the image size specified in the settings. In other words, for the JPEG only it throws away a portion of the collected data but you will still see the entire image from edge to edge. If you shoot JPEG + RAW you'll see the difference in the file sizes and if you zoom in to, for example, 100% crop on both you'll see that the JPEG is much fuzzier (less resolved). If you save the image as a web-sized file or print it only in a small (eg. 4 x 6) print you won't see any visible difference but you would not be able to print a small file at a much large size.
08-29-2007, 11:42 AM   #6
mattdm's Avatar
QuoteOriginally posted by LKeithR Quote
"Much" is an overstatement. In most cases, you'd be hard pressed to pick the differences even at pixel view. The big advantage of RAW is in the higher dynamic range and unadjusted gamma curves.
08-29-2007, 02:42 PM   #7
QuoteOriginally posted by mattdm Quote
That's 2 advantages. 3rd is WB adjustability. 4th is Silkypix which just gives super duper colours compared with jpgs.
08-29-2007, 04:55 PM   #8
Lowell Goudge's Avatar
Aside from saving memory space why would anyone use a 10mP camera to save 2MP images.
You would be better off by changing the Jpeg compression from low to high, but remain at 10MP
camera, dslr, k10d, megapixels, photography
Question about megapixels justtakingpics Troubleshooting and Beginner Help 7 05-13-2010 10:09 AM
Lenses and megapixels ntx Troubleshooting and Beginner Help 37 05-05-2009 11:50 PM
Megapixels vs. Noise stgmgr Troubleshooting and Beginner Help 7 02-24-2009 12:37 AM
Difference between 6 and 10 megapixels explr1 Pentax DSLR Discussion 13 08-22-2008 07:43 PM
Megapixels and cropping pcarfan Pentax DSLR Discussion 11 09-30-2007 05:13 PM
All times are GMT -7. The time now is 11:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
