08-27-2010, 05:26 PM   #31
Pentaxor's Avatar
QuoteOriginally posted by pcarfan Quote
Which blue artifacts?
I didn't want to do ETTR here, as then I would hear some say, use a lower iso, these were all taken at EV 0
sorry, I meant the blue noise which is not uncommon at higher ISOs.
no problem if you didn't do ETTR, you still got some very good results. I mentioned ETTR since it would make the image look a lot better or let's say look more plasticky.
08-27-2010, 06:09 PM   #32
pcarfan's Avatar
QuoteOriginally posted by Pentaxor Quote
Oh! I see what you mean. I thought there were some noise that appeared blue not blue channel noise...the reason I asked was to see where it is, as when I posted some high iso shots earlier, someone pointed out some banding which I hadn't seen and it was a great learning experience, was wondering whether this could be another learning opportunity.
Thanks though.
Also, just checked and LR3 has a significant chroma NR in default, but as it doesn't affect IQ, it's ok, but that is obviously reflected in the cleaner image here as well.
08-27-2010, 08:24 PM   #33
JohnBee's Avatar
Great shots(all of them).
Goes to show what can be accomplished with a good shooting method!
PS. It might be the JPG translation, but it looks as though there is NR(in camera?) at 100%
08-27-2010, 08:29 PM   #34
ivoire's Avatar
Excellent series, enjoyed them all!
08-27-2010, 08:33 PM   #35
Christ dude! those photos are terrible, full of noise and shutter blur! I can't even see the mans pupils clearly! you need a FF or APS-H Pentax! :P
Great shots!
I ditto your comment on firmware 1.10, it definitely improved High ISO performance to a degree.
08-28-2010, 04:29 AM   #36
pcarfan's Avatar
QuoteOriginally posted by JohnBee Quote
John, it has to be the default LR3 NR (which there certainly is a significant amount for chroma). I can't look at an image and tell NR yet, but that's porbably what you are seeing. Shot at iso 3200 there is definitely in-camera NR even with RAW (as Gordon Good ?, had discovered) and you could be seeing that as well.
John, there is no such thing as a 'good shooting method' here, just point and shoot (shot in RAW in Tv mode, EV0 and opened in LR3 and saved as jpegs, that's it)...you must be mistaking me for someone else
08-28-2010, 04:31 AM   #37
pcarfan's Avatar
QuoteOriginally posted by ivoire Quote
Ivoire, Thank you!....I bet you are hoping Pentax will announce some new long glasses at photokina, hah!
QuoteOriginally posted by Christopher M.W.T Quote
Great shots!
Noise, shutter blur, unable to take any sharp shots, yup! that pretty much sums us Pentax, right....ROFLOL.
Thanks, dude!
08-28-2010, 05:53 PM   #38
ivoire's Avatar
i'm still looking for a sharp, affordable 500mm. the dream is alive
08-28-2010, 06:10 PM   #39
Ex Finn.'s Avatar
Thanks a lot, now I feel the need for one of them Limited jobs.
I used to be happy with my smc a 50-1.7`s
08-29-2010, 05:04 AM   #40
pcarfan's Avatar
I hope it becomes a reality, I need one of them real bad as well
QuoteOriginally posted by Ex Finn. Quote
A 50/1.7 is one sweet lens, yeah! the limiteds would offer a bit more, but you are not leaving much on the table with that amazing A50/1.7.
08-29-2010, 10:51 PM   #41
Impressive. I've avoided anything above 1600 till now. This encourages me to give something higher a try.
Thanks for sharing.
08-30-2010, 03:59 AM   #42
pcarfan's Avatar
QuoteOriginally posted by pinholecam Quote
Thanks for sharing.
Well! it could be used in a pinch, but high iso can never be iso 100 or 200 which IMO are the only iso's that is suitable when things like ultimate IQ matter in large prints or if cropping is needed. All this talk of high iso pefromance is all about which one does a less shitty job. I'll take iso 50 over nicer iso 6400 any day. So, don't get your hopes high, but for relatively small prints these high iso's are fine!
08-30-2010, 04:50 AM   #43
Pentaxor's Avatar
I guess this statement is true.
until such time when ISO 6400 is as good as ISO 100, then I'll be on cloud 9 by then.
*although for small prints and small viewing pleasure, HIGH ISO is fine as you said.
08-31-2010, 08:13 AM   #44
Class A's Avatar
Also, just checked and LR3 has a significant chroma NR in default...
Do you know that it is your choice how much chroma NR LR applies per default?
Just chose an amount you like in the Develop module and then press the "Alt" key ("Option" on a Mac). The bottom right button will change into "Set Default...". Press this one and, voilą, you've got a new default NR setting.
With the correct preference setting the "Develop module default settings" can be different per ISO value (and/or camera). Very useful.
BTW, #5 from the original series was my favourite. Perhaps because it looked the most real and didn't contain a "Canon" face.
camera, dslr, images, iso, k-7, k-7 iso, nr, photography, plastic
Noisy high iso images are useful alehel Pentax DSLR Discussion 17 04-07-2010 08:28 AM
K-7 iso 3200 images at the Airforce Museum(double post) pcarfan Pentax DSLR Discussion 22 09-06-2009 06:03 PM
k7 FW1.0 high iso images available John Cafarella Pentax News and Rumors 21 06-19-2009 02:31 PM
High ISO concert images with Tam 28-300 (Images) jsundin Post Your Photos! 2 07-05-2007 08:19 AM
Faces of Watoto (6 images in relply) atupdate Post Your Photos! 9 05-23-2007 10:35 AM
All times are GMT -7. The time now is 12:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
