08-29-2010, 08:52 AM   #1
Screw Mount lens on K100DSuper
New to this and definitely an amateur. I have MANY screw mount lenses (70's) so just purchased a K100DSuper body with adaptor to utilize these lenses. I have tried everything to attach the adaptor and lens and can not focus. The adaptor appears to hold the lens too far from the camera, because if I hold the lens where it should be positioned, things are in focus. I purchased a T-Mount f/Pentax K online with the camera body. HELP!
08-29-2010, 09:59 AM   #2
boriscleto's Avatar
This post should probably be in the Beginner's Corner. Your problem is that you bought a generic adapter that doesn't allow infinity focus. An adapter that allows infinity focus will sit inside the camera.
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-screw...ml#post1140019
08-29-2010, 10:17 AM   #3
Thank you.
08-29-2010, 10:30 AM   #4
pacerr's Avatar
QuoteOriginally posted by cyfly Quote
Or perhaps you have a T-mount adapter rather than an M42 - K adapter?
Hang in there. Once you sort out the adapter you'll be pleased with the results from your screw mount lenses on the DSL.
H2
08-29-2010, 11:04 AM   #5
Ira
Go to the Pentax store and buy their adapter.
08-30-2010, 07:29 AM   #6
Does your adapter look like this:
Pentax K Mount Universal M42 Screw Camera Lens Adapter - eBay (item 220660364495 end time Sep-02-10 09:29:12 PDT)
or this:
M42 Lens Adapter Ring for Pentax K mount K200D/K110D - eBay (item 280510145177 end time Sep-18-10 01:10:14 PDT)
The first one is not a genuine Pentax adapter, but it is identical. It fits entirely within the k-mount opening on your camera. It is flush with the lens mounting surface. This type of adapter will allow infinity focus.
The second one has a large flange that sits OUTSIDE the k-mount opening, adding a mm or two to the lens-to-sensor distance. This will definitely prevent infinity focus.
If you have the second type, that is almost certainly your problem. If you have the first type, then something else is wrong.
This is a t-mount adapter:
T- Mount T2 Adapter for Pentax K Film Digital SLR - eBay (item 130424558068 end time Sep-23-10 21:11:51 PDT)
Note how thick the t-mount adapter is. In addition, while the t-mount thread looks similar to the M42 screw-mount, it is not the same. Both are 42 mm in diamter, but the M42 is coarse thread (1 thread/mm) while the t-mount is fine thread (0.75 thread/mm). Trying to screw an M42 lens into the female end of a t-mount adapter will damage the threads of the lens, the adapter or both. And it won't work anyway. An M42 lens would be WAY too far from the sensor. You probably couldn't focus further than about five feet, depending on the lens.
adaptor, body, camera, dslr, focus, k100dsuper, lens, lenses, photography, screw, screw mount lens
screw mount lens aperture stuck.. Gooshin Pentax SLR Lens Discussion 15 01-21-2009 11:11 PM
M42 screw mount lens diaphrams! Robert Barnes Pentax SLR Lens Discussion 13 08-12-2008 12:42 AM
? about M42 screw Lens to K mount adapter whitedogone Pentax SLR Lens Discussion 15 07-18-2008 01:39 PM
Screw mount lens on a k10d question GatorPentax Pentax SLR Lens Discussion 8 12-03-2007 11:31 AM
Screw mount SMC Pentax lens FLASH Pentax Film SLR Discussion 23 03-04-2007 09:24 PM
All times are GMT -7. The time now is 05:38 PM. | See also: NikonForums.com, part of our network of photo forums!
