08-30-2010, 09:59 AM   #1
SR causing double images on K-m
Recently, I have been getting a lot of pictures with motion blur at shutter speeds of around 1/100 of a second. Bellow is an example taken at 1/80 of a second at 35mm f/8 on the K-m. SR was on.
Over half of the pictures I took the same day as this one have a double image.
I tried turning off the Shake Reduction and this problem stopped. When I turned SR back on, I got more double images.
When I first got this camera a year and a half ago I didn't have this problem.
Is my only option to stop using SR?
PENTAX K-m  Photo
08-30-2010, 12:00 PM   #2
fccwpe's Avatar
Is the camera on a tripod? If it is then the shake reduction introduces shake when it is turned on. Strange but true.
08-30-2010, 02:18 PM   #3
I think the real question is "what changed?" If it's the use of the tripod, fccwpe has it right.
Otherwise, another SR mystery.
08-30-2010, 05:53 PM   #4
I did not use a tripod for the above picture.
Over the past few months I have been getting an increased number of blurry pictures. I thought I needed to hold the camera more steadily, although that made no difference. The problem just seemed to get worse. I used to get some pictures with motion blur, but not many. Now, over half of my pictures taken at shutter speeds from 1/60 of a second to 1/125 of a second show motion blur. The motion blur varies in severity and is always in the same direction. The problem disappears when I turn Shake Reduction off.
camera, dslr, half, images, k-m, photography, pictures, sr
how do you stitch a panorama without causing a distortion on the images? rustynail925 Photographic Technique 20 09-13-2010 04:27 AM
K-7 iso 3200 images at the Airforce Museum(double post) pcarfan Pentax DSLR Discussion 22 09-06-2009 06:03 PM
what's causing this weird yellow tint ? chiem Pentax DSLR Discussion 17 03-11-2009 06:43 AM
IE causing problems with posts? FHPhotographer General Talk 14 01-22-2009 01:16 AM
any idea what's causing this? FHPhotographer Pentax DSLR Discussion 15 12-08-2008 12:50 PM
All times are GMT -7. The time now is 12:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
