08-31-2010, 03:52 PM   #1
How would i know weather i've demage the lens/camera
Hi all,
I am new in here, and i would like to ask you:
Yesterday i got my new Tamron 70-300 DI-LD macro. and somehow after i attached it to the camera body, which is also new, i accidently pushed in the focus ring while the camera was on AF mode.
How would i know if i have damaged the lense/the camera?
Thanks allot,
Dror
08-31-2010, 04:25 PM   #2
Ira
QuoteOriginally posted by DROREN Quote
Hi all,
Thanks allot,
Dror
Does it continue to work in Autofocus mode? If so, you didn't damage it.
It usually takes more than one mistake to damage a lens this way.
08-31-2010, 04:32 PM   #3
Aegon's Avatar
If you turned the focus ring while the camera was in AF (not MF) mode, then you probably had some resistance from the motor and it probably made a whirry sound. And it isn't likely to cause damage unless you do it quite often.
09-03-2010, 11:20 AM   #4
Thanks very much for the quick answer!
Yes, it does continue to work in Autofocus mode.
It is quit a relieve for me knowing that...
09-03-2010, 02:22 PM   #5
zerodaze's Avatar
Okay, just don't do it again.
Welcome.
09-07-2010, 09:30 AM   #6
crossmr's Avatar
I have this lens, I find it's a little finnicky going on and off. I have to be careful to grip it just so to make sure I don't accidentally give it a twist.
camera, dslr, photography
Which weather proof camera? Mallee Boy Pentax Compact Cameras 9 09-26-2009 09:44 AM
Weather Proof your lens??? Jewelltrail Pentax Camera and Field Accessories 19 05-12-2009 11:05 AM
non-weather sealing lens annod Pentax SLR Lens Discussion 4 01-18-2009 04:25 AM
Hot Australian weather and camera care Vylen Pentax DSLR Discussion 11 01-08-2009 02:35 AM
Weather Resistant lens jbrowning Pentax SLR Lens Discussion 2 02-26-2008 06:34 PM
All times are GMT -7. The time now is 04:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
