08-31-2010, 04:49 PM   #1
Blue's Avatar
K200d dial issues
Well, today my K200d started giving me some issues somewhat similar to what Yeatzee described in this thread.
https://www.pentaxforums.com/forums/pentax-dslr-discussion/91847-pentax-k200d...roblems-2.html
However, not exactly. The Dial well only select M, AV and B. I shoot in M and Av so much, I didn't notice it. What got my attention is that the SR was coming up as off even though it was on. The AF/MF switch was working backwards as well. It wasn't prompting me for the focal length of my Tak is what got my attention. The Green Button quit working as well. I reset everything to default and reprogrammed all of my settings. That got back my green button and SR. However, It looks like I am stuck with the M, Av and B modes as far as the dial goes. This body has basically served as my P & S since May 31, 2008. I guess the K20d is going to start carrying more of a load. I really don't to pay $200 to have a dial switch fixed that shouldn't wear out under basic use. This is more of a calm rant than anything.
08-31-2010, 04:52 PM   #2
yeatzee's Avatar
Sorry to hear.....
But whats REALLY odd, is that I just checked my K200d after reading the above and its working fine in AV mode with my Pentax DA 55-300mm it appears as far as i can tell to have reverted back to its original working condition
WTF?
08-31-2010, 04:57 PM   #3
wlachan's Avatar
Have you by any chance using high voltage batteries which might drive the electronics insane?
08-31-2010, 04:58 PM   #4
yeatzee's Avatar
QuoteOriginally posted by wlachan Quote
I've used the same batteries since the day I got the camera (eneloop rebranded duracell).
08-31-2010, 05:01 PM   #5
wlachan's Avatar
I would have to say either high temperature or humidity might be the cause then since it is normal now.
08-31-2010, 05:10 PM   #6
yeatzee's Avatar
I continually used the camera until/after I got my K-7 (took me a little while to save up for one) for several months and it still only worked in M mode with modern lenses. There's no way it was something natural that caused it...
08-31-2010, 06:01 PM   #7
Blue's Avatar
I have only used the Energizer Lithiums or the Kodak rechargeables that I have always used with it. I also keep it out of heat storage and minimize its exposure to humidity. The camera works fine in M and Av modes once I "rebooted" the thing to get the SR and Geen button back.
08-31-2010, 08:19 PM   #8
Hi Blue
Have you tried a new set of Lithiums since you have had the problem, your rechargeables maybe wearing out and causing the problem. It's something to try.
Rick
08-31-2010, 09:14 PM   #9
Blue's Avatar
QuoteOriginally posted by Rick in Ohio Quote
Hi Blue
Rick
I swapped out the batteries and got the dial and af button working. I restarted with the FA 50 on there. The AF button was a bit dodgy at first.
08-31-2010, 09:23 PM   #10
yeatzee's Avatar
thats odd
I guess we had entirely different problems?
08-31-2010, 09:28 PM   #11
Blue's Avatar
QuoteOriginally posted by yeatzee Quote
thats odd
It turns out that my problems were related to the AF-MF switch and the SR switch. The mode dial was actually ok when I put the FA 50mm on there. I thought the dial was the culprit because the green button wouldn't work until I reset the camera. That got the green button going again and eventually the SR. Swapping out the batteries got the AF going again.
09-01-2010, 09:22 AM   #12
Marc Sabatella's Avatar
Not really related at all, but FWIW, a couple of weeks ago I was starting to get the sense that my K200D shutter button was starting to fail - a bunch of times when pressing the shutter did nothing until I pressed it harder than I thought I normally needed to. Or else it felt like it was sensitive to *where* on the button i was applying pressure. But after a few days, it seems back to normal now. Or else I got used to it.
attention, av, button, camera, dslr, issues, k200d, photography, sr, switch
K-7 exposure dial not going down? Help please netuser Troubleshooting and Beginner Help 8 07-26-2010 11:20 AM
Sun Dial tpeace Monthly Photo Contests 2 01-10-2010 05:01 AM
K200D battery issues. Pif Pentax Camera and Field Accessories 9 04-10-2009 05:53 AM
What is your e-dial default? jjay Troubleshooting and Beginner Help 7 03-11-2009 10:37 PM
Is my K200D bad? Point of focus issues! cputeq Pentax DSLR Discussion 10 05-05-2008 09:05 AM
All times are GMT -7. The time now is 06:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
