09-01-2010, 12:43 PM   #1
jpzk's Avatar
Front dial intermittent issue on the K20D
Hi everyone.
As recently as yesterday, I, for the very first time, had an intermittent problem with the front dial of my K20D:
I have set this dial, in Av, for ISO settings (whereas the rear dial is set for setting shutter speed) ... and it just refused to work until I:
1. turned the camera and the grip off ... still refused to work.
2. turned the camera/grip off and removed/reinserted the battery and this time it did work but only after having "played" with the front dial a few times.
I tried it this morning and all was fine.
I am wondering if this is a prediction of future/permanent problems with the front dial or that maybe it was just a "glitch".
I would appreciate anyone's comment or advice of this.
Cheers.
JP
P.S.: my K20D has roughly 25,000 actuations.
09-01-2010, 01:19 PM - 1 Like   #2
imtheguy's Avatar
I know you have been around the forum long enough to see similar threads where the grip has a dial partially turned. Just though I'd make sure you remembered seeing them.
09-01-2010, 01:41 PM - 1 Like   #3
Ash
Community Manager
Ash's Avatar
Yep, it's an established issue, but not one to cause long term problems - just readjust with the grip e-dial and see the camera e-dial work again.
09-01-2010, 04:59 PM   #4
QuoteOriginally posted by imtheguy Quote
Thanks guys for the tip, i did not know that. I never had a problem with the grip attached. So I'll try to remember when this particular incident arises.
09-01-2010, 06:19 PM   #5
jpzk's Avatar
So, I did look for a specific answer to this question ... which means: I will go back and look again.
Sorry about the mishap.
09-01-2010, 06:20 PM   #6
jpzk's Avatar
Thanks Ash ... reply much appreciated.
Sorry for taking time on frivolous questions which I should have found in the first place.
JP
09-01-2010, 06:21 PM   #7
jpzk's Avatar
I believe this thread should be closed indeed.
JP
09-01-2010, 07:21 PM   #8
Jodokast96's Avatar
Sticky pins are also a possibility.
09-03-2010, 05:37 PM   #9
jpzk's Avatar
QuoteOriginally posted by Jodokast96 Quote
Thanks!
I did check this after reading your post ... all clean and non-sticky!
JP
camera, dslr, front, k20d, photography, time
Front Focus issue, a wierd one. Only with manual lenses. the swede Pentax SLR Lens Discussion 25 06-28-2010 07:42 PM
FA 50 1.4 front focus issue phler2 Pentax SLR Lens Discussion 7 12-24-2009 06:46 AM
Front-back focusing issue Mystic Pentax DSLR Discussion 10 08-26-2009 08:15 PM
Front focus issue, but unable to correct - What now? enoxatnep Pentax SLR Lens Discussion 11 12-28-2008 10:34 PM
K20D softness, intermittent davemdsn Pentax DSLR Discussion 3 06-08-2008 05:01 PM
All times are GMT -7. The time now is 10:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
